Sawing a 22' Oak on a 21' Deck
Started by Sawdust Lover, February 10, 2013, 07:24:37 PM
Dave Shepard
Sawdust Lover, that timber looks great. Is that white oak?
I handle over length logs similar to what Losttheplot does. I like to slide the log on a sawn surface, this makes it much easier to align the log to the bed.
1- I level the log to the bed and make my opening cuts. I saw as far as I can and then cut the slab/board with a chainsaw. We got an electric after the first couple of logs. It was high '90's when we cut these and the gas saw wouldn't start the second cut of the day.
2- Turn 180° and repeat to desired thickness. Once you have something like the hammer head in the first pic, you slide the log back a couple of feet and cut the hammer head off in one chunk.
3- Slide the log back to the original position, and rotate it up 90° repeat.
47' log on an LT40 with a 24' bed extension:
