The 2012 Great Firewood Shoot-Out/Paul Bunyan Show
Started by Walter, June 21, 2012, 09:29:40 AM
Walter
The 2012 Great Firewood Shoot-Out/The Paul Bunyan Show
October 5-7, 2012
Guernsey County Fairgrounds
Cambridge, OH
Ph: 1-888-38-TREES
www.ohioforest.org
www.sawmillmag.com
Here is some info for the seminars taking place at the Paul Bunyan Show.
Friday October 5, 2012
9:00 AM to 10:30 AM
Wood 101: Wood as a Raw Material. Wood is a wonderful raw material to work with, but it does have some unique features that can lead to problems while processing and in use. This seminar will discuss some of the main issues related to the use of wood and how to avoid associated problems. These issues include a understanding of water in wood, how to measure water in wood, why wood shrinks and swells, maintaining moisture content of dry wood, the variability associated with wood and abnormal wood and its impact on processing.
Presenter: Brian H. Bond---an Associate Professor and Extension Specialist in the Department of Wood Science and Forest Products at Virgin Tech.
11:30 AM to 1:00 PM
Drying for the Small Operator. This seminar will cover the basic information that a small operator should know and consider regarding the drying of hardwood and softwood lumber, including suggested drying methods for small operators, the basics of how wood dries and defects associated with drying.
3:00 PM to 4:30 PM
Firewood A to Z.  Take this class if you would like to make sense out of firewood, from the buyer, seller, producer or landowner perspective.  All aspects of firewood will be discussed; with the steps to produce seasoned, dry wood and how to get the most out of it.  Whether you are a landowner, logger, processor, hauler or end user, your questions will be answered and methods to make your work easier and more productive will be presented.  Learn about the equipment you may need and how to make sense and possibly a dollar in the hot firewood markets.
Presenter:  Mark Havel is an engineer, forest landowner, founder and Pres. of Future Forestry Products Inc and the originator of the modern log arch line.  Mark is from Oregon in the Pacific Northwest, where he teaches classes and leads field day workshops on forestry tools and techniques.
Saturday October 6, 2012
9:00 Am to 10:30 AM
Basics of Hardwood Lumber Grading. This seminar will introduce participants to the standard grading rules of the National Hardwood Lumber Grading Association and demonstrate how they are applied.
11:30 AM to 1:00 PM
Methods for grade sawing hardwood logs. This session will cover how to apply the grade sawing technique to hardwood logs on a portable sawmill. The session will start by presenting the concepts of grade sawing followed by the actual application of the concepts to hardwood logs using a portable sawmill. This session will require attendees to actively participate in applying the knowledge presented!
3:00 PM to 4:30 PM
Chainsaw Sharpening and Use Techniques.  Whether you have a few hours or a few years behind a chainsaw, this class will help you cut more efficiently, effectively and safely with a sharp chain and the right techniques for felling, limbing and bucking.  Does that leaning tree bother you?  Working in tight stands where everything hangs up?  Does your saw cut straight and fast?  Take this class and step it all up a notch, for the beginner or experienced sawyer, happiness is wood on the ground.
DR Buck
The show this year made Fox & Friends Saturday morning !!! .................   and I thought I was going to miss it completely this year.    :)
