Anyone attached a post hole digger to log loader
Started by Retired-Jack, December 28, 2012, 06:22:24 PM
Retired-Jack
Has anyone attached a post hole digger or auger to the grapple on their log loader.
I think I could make a bracket to hold an auger and rotate the grapple
to dig holes 8 inch wide, 3-4 feet deep.
If I could find a second-hand bit I would give it a whirl.  Princess Auto has bits for around $150.
If you were successful in digging holes what size bit did you use? Any suggestions?
I have a Patu 202 log loader.
Tj 201 Patu loader SMG Sawmill
Maine372
I saw a pic in a logging publication several years ago. guy took a earth auger, probly 12" diameter, and welded a square piece of steel on the end. all he had to do was grab it with the grapple on his 120prentice and use the continuous rotation.
amberwood
yes I have done it. we fitted a cross bar to the end of the auger, fed it through the grapple on the forwarder and drilled away. Not quick but faster than a shovel. The challenge is keeping it centered.
DTR
MS460 Magnum
MS250
DAF CF85-430
ASV RC-85 track loader
