Should I idle or turn it off?
Started by YellowHammer, January 22, 2013, 12:23:29 AM
YellowHammer
You all got me thinking (not usually a good thing :laugh:), I ordered the WM belt tension gauge today,  I just hope I can figure out how to use it.  :D
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
I would say on an electric mill such as a WM leave your engine at a fast idle to keep the battery up.Non electric mill anything over 10-15 min shutdown.My bandmill is electric I shut it down when wrangling logs or moving boards around,prehaps too much.The old Dagenham diesel on the circular mill stays running except for lunch. A warm running diesel is not wearing anything running, except a hole in your pocket for fuel. Frank C.
