Lombard log hauler sleds
Started by loggah, April 16, 2016, 07:57:03 PM
loggah
 I  saw another post about what  project  are you working on, and decided to post about the log hauler sleds i have been building  this spring. The maple sugaring season was pretty much a bust  for those that used buckets,and i said skip it this year and get my log hauler sleds built.
I had a bunch of lombard sled irons,some black locust and red oak  sawn out years back for skis and bunks, and sawed out some white ash a few days ago for reach poles.  Been playing old time blacksmith and wood butcher for over a month and finally finished today !!!!! Two sets of sleds and reaches just under 60 ft. long and probably 2 1/2 tons  . Now  i just have to cut 5 or 6 thousand ft. of hemlock to make display loads. !!! ;D
Interests: Lombard Log Haulers,Tucker Sno-Cats, Circular Sawmills, Shingle Mills, Maple Syrup Making, Early Construction Equipment, Logging Memorabilia, and Antique Firearms
r.man
Good grief that is a lot of work. Looks great, do they have an inside home?
Criss crossed?? So they follow better?? That does look good and than some!!!!
loggah
I am going to soak them down with an oil and diesel fuel mixture, the stack them up and cover them. Many,Many bolts in those things  ;D. lombard patented his sleds,with the irons and the crossed reach poles, so they would all track the same, no one before had done that, at times they had as many as 20 sets of sleds behind one tractor. Don
Peter Drouin
I was up to Mr Hoyts the other day buying some logs . I see Top Notch has some logs you can use for your display.  Your brother has a nice up.
A&P saw Mill LLC.
License NH softwood grader.
barbender
     That is some kind of nice, Loggah! You do really nice work ;)
loggah
I made them pretty much like the  originals,most of the logging operators back in the day just bought the irons from lombard and built them with their own wood. Peter he runs a pretty good operation, the Asplund guys have been working out of their yard for a while also.
coxy
nice job  8) 8)   i like how you off set the bolts in the cross pieces to keep it from splitting
47sawdust
I would be sitting down too,that is a lot of work.Excellent job.I've built a couple horse drawn work sleds that were cross chained so the rear followed the front.
After seeing your work the bar for quality is set pretty high.
Thanks for the inspiration.
Mick
Mick
petefrom bearswamp
Nice job!
When I hit 80 (the current target date, the last one was 75) and finally retire from sawing I plan to visit a bunch of FF member to occupy my time and would love to see all of your projects as well as the things other members do.
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
Bruno of NH
Don you are a historian  :)
And you do great work , would like too meet you one day .
Jim
coxy
Quote from: petefrom bearswamp on April 17, 2016, 08:00:18 AM
Nice job!
watch out guys you will never get anything done  :D :D when you hit 80 you will still be sawing you will say ill quit at 85 and i hope your 100 and still sawing 8) 8) you a MM could start a new buss called (old fogey sawing and resawing and sawing again) :D :D :D :D :D :D :D sorry had to have a little fun  ;D ;D
I am just proud to be in such good company.  I have a full sawing schedule ahead of me for this week.
loggah
I probably wont be sawing much this summer, after the sleds are put away i have to start on my 28' x84' pole barn,i have the beams and 2x6 and the 2x8's all sawn from last fall. I am pretty much a dub good at making heavy crude things,and working on old iron.You guys with the modern stuff are light years ahead of me !!! ;D
711ac
I do enjoy your posts Loggah!
Dakota
When loggah posts,  I know it's going to be interesting.
Dave Rinker
barbender
yukon cornelius
Wow! That is an awesome set up! Were those sleds used only in snow or would they have been in use all year?
It seems I am a coarse thread bolt in a world of fine threaded nuts!
Making a living with a manual mill can be done!
loggah
The sleds were only for use on snow. Lombard did make some heavy wagons that would track behind each other for summer use.
