Stihl 084
Started by kskingfish, March 08, 2013, 06:01:48 PM
kskingfish
All, I have been using a Stihl 084, with a 48" bar and rip chain with an Alaskan saw mill and mini mill to get my furniture grade lumber. The saw has quit oiling, and looking for advice for rebuilding the oil pump, or location of an oil pump kit. Or even an blown 084 that I could possibly parts out? Any ideas?
Thanks,
POSTON WIDEHEAD
Welcome to the Forum.  :)
SPD748
Welcome to the forum! I agree with David, post over on the chainsaw section. There are many fine fellows there to answer your questions.
-lee
Frick 0 Handset - A continuing project dedicated to my Dad.
410 Deere, 240 Massey... I really need a rough terrain forklift :)
Sawing Since 1-19-2013 @ 3:30 pm
Serving Since 2002
"Some police officers give tickets, some gave all."
AdkStihl
Make sure the oil pickup body is clean of any debris and check that all oil passages are clear before spending any $
J.Miller Photography
Al_Smith
It might not be the pump itself .I've never worked on one but according to the IPL the pump is driven by a tab protruding from the clutch drum .It could well be the linkage to the pump could be faulty  not driving the pump .
kskingfish,welcome to the forum. We do have CHAINSAWR on the left as a sponsor,4th one down,if you do need something.
furniture grade lumber?? What do you make?
mad murdock
Baileys has a lot of new replacement parts. I know that for the 044 sized stihl's a new pump assy is around 40 bucks. Can't imagine a new pump for an 084 being a lot more.
qbilder
Ever considered using an outboard oiler? Lots of CSM millers attach a tank yo the mill & run a drip tube from the tank to the bar. Milling is demanding and requires a good flow of oil. Even with the saw oiling well, it might be something to look in to.
My 084 oils real well. So far I haven't had any issue with it not oiling, but have had other saws stop oiling. It's most generally something easy & simple like a piece of debris plugging it up on one end.
God bless our troops
s grinder
kskingfish,replaced a oil pump on my friend's 084 last spring,spline gear was worn to the point that it was slipping causing the oil pump not to work.We went to the Sthil dealer and parts were available to my surprise,if not now i'd go to Chainsawz or Baleys,some parts are on that saw are starting to be hard to get.
s grinder
Quoteif not now i'd go to Chainsawz or Baleys,
Did you mean Chainsawr (sponsor on left) ?
s grinder
beenthere yes.chainsawr
