HELPPPPPP!!!!
Started by strunk57, March 29, 2013, 07:06:57 PM
learner
strunk57 I'm not one to argue about sawing techniques but I find sawing from the large end to the small end easier.  When dealing with logs larger than your saws throat opening, it's very easy to get jambed up on the far end by sawing from small to large end.  I allways try to make the first cut so that i get at least a 4" board from the second cut so sawing from the small end to the large end can take more time and cause some heartache.  By sawing from the large end i can eleminate the short cuts faster and get the cant to an easily sawable size faster.
WoodMizer LT40 Super Hydraulic, MF-300 FEL, Nissan Enduro 60 forklift, 2 Monkey Wards Power Kraft Radial arm saws, Rockwell series 22-200 planer, Prentiss 210 loader
strunk57
Learner, I read that when sawing ERC you want to start from the small end because the blade tends to follow the knots up resulting in uneven lumber. I see your point though.
99 timberking b-20. John deere 450c loader. 79 Chevy c-60 95 GMC 2500, Craftsman tablesaw, Dewalt 735 13" planer, stihl ms-290 Stihl 029, Husqvarna 394xp, dewalt router & table, various sanders/hand tools.
strunk57
Think this may be part of the problem, this is on the non-drive side band wheel.
Also had some bad luck AGAIN today, i was trying to set my blade guides and the thread on the left side stripped out, so now i have to re-tap tomorrow, i really dont like this on the norwood mill, i think it is a bad setup, the roller shaft is really loose in its hole and just a bolt against the shaft to hold it in place, i think i may make another support arm that holds the shaft tighter.
strunk57
On a good note, it is possible to mill some nice wood, i cant wait to get set up right, i have 6 good size ERC to finish, i really love working with cedar and there are a lot of it in my area.
