Bigger Roller Guides?
Started by highleadtimber16, June 05, 2013, 01:10:15 AM
highleadtimber16
Hi Guys, I was thinking about ordering some new 1 1/2" roller guides to replace my 1 1/4". For the people who have done this, have they noticed a big difference in reduced wavy cuts and faster sawing? At $75 a piece I wanted to get some input before buying them. I'm cutting mostly cedar and some bigger doug fir. I'm running  regular 1 1/2" WoodMizer blades.
Thanks,
2011 Wood-Mizer LT 40 hyd w/ 12' Extension,
EG 200 Wood-Mizer
Cutting Old Growth Cedar from Queen Charlotte Islands.
JustinW_NZ
Gear I run;
ladylake
It sure seems like a wider roller guide would control the blade better.    Sreve
Highlead,which are we talking about the diameter of the guides or the width.If boath are are adjusted right it shouldn't make any difference so far as diameter.As far as width if you run 1 1/2" bands by all means use 1 1/2" guides likewise with 1 1/4".If your present guides are worn replace them with the larger diameter with the proper width for your bands.Bad bearings can be replaced rather cheaply.Most guides are hardened and difficult to remachine to eliminate wear on the ends. Frank C.
highleadtimber16
Went and ordered them this morning, should be here friday. Let's hope they make a difference!
EG 200 Wood-Mizer
haywire woodlot
Keep us posted on the results, Highlead!
Dave
dboyt
Back when I ran a TimberHarvester, I switched from 1-1/4" to 1-1/2" blades and guides.  I did help, though the blades were a bit more expensive.  I think you'll find it was a good move.
