frost free outhouse seat
Started by james, April 25, 2004, 03:43:56 PM
james
if uou take a sheet of 1/4 plywood cut to the shape of the seat , glue a pece of 1 inch blue or pink foam (two holler -his &hers??? :D :D :D)  to it and carve it to the proper shape it keeps da bum from getting cold-even in sub-0 weather
 8) 8)
Frickman
Wish they had that foam back in the good old days.
Bro. Noble
I would avoid using fiberglass insulation board :o :D
