The old chicken coop
Started by Haleiwa, December 20, 2019, 01:57:53 PM
Haleiwa
I needed a place to set up to sharpen chains and bandsaw blades.  The most convenient was an old chicken coop that had been used to store junk for the last forty years.  The floor was old broken up concrete that wasn't good for anything, and there was no insulation in it.  I broke up the old floor, added some fill to level it up and poured a new floor.  I hired a teenager to help; he doesn't get tired as quickly as I do.
I had to replace the windows with something that would help keep some heat in, and a lot of old cedar siding that was broken up or missing. Then I framed out the inside, ran wiring, insulated, and drywalled.
I built a bench from ash, and moved the sharpening equipment in.  Because it is such a small space, I made a system where the sawblade setter, chain breaker, and rivet spinner can all be mounted on the bench as needed, and then stored  out of the way.
The chain grinder and a small press occupy the end with the nice window.  Normally I won't even look at anything from Harbor Freight, but this little press that I bought secondhand is just the thing for straightening harvester bars.  It paid for itself in a short time.
Painting will have to wait until spring, as will adding a better heat source.  Right now I am using two electric heaters, but I have a wood stove that will work better once I get a pipe through the wall for it.
Socialism is people pretending to work while the government pretends to pay them.  Mike Huckabee
Okefenokee_D
Awesome! Nice that you redone it to fit your needs rather than tearing it down.
Pine Ridge
Nice job, having a good place to work on saws and chains makes it much more enjoyable.
Husqvarna 550xp , 2- 372xp and a 288xp, Chevy 4x4 winch truck
BargeMonkey
 I can't recommend a borzon wheel enough for a grinder, makes a nicer grind and no hassle like a ceramic wheel. Saw room is nice on the cold days, I go drink beer and make /sharpen chain, quiet 🤣
barbender
I could live in that thing!👍👍
Peter Drouin
A&P saw Mill LLC.
License NH softwood grader.
47sawdust
Barge...I don't know you,but you and quiet are kind of hard to imagine ;D.
Great re-purpose on the chicken coop.
Mick
alanh
Great job on the coop/shop...although I have to ask, where did you find a teenager willing to do that? We might have to capture him for study and future cloning.
Ed_K
 What kind of setter is that? Looks like mine that has no name plate.
Ed K
WV Sawmiller
   Pretty fancy digs for a chicken coop if you ask me. Well done.
John S
2018 LT40HDG38 Wide
Haleiwa
Quote from: Ed_K on December 21, 2019, 09:40:59 AMWhat kind of setter is that? Looks like mine that has no name plate.
It's an old Woodmizer that I got when I bought my mill secondhand.  They still carry some parts for it.
A-z farmer
Very nice repurposed use of the chicken house Haleiwa.
One of our farms was a chicken farm 50 years ago and many buildings have been just sitting empty.
After seeing what you have done i should try and save them for a good use .
Zeke
SawyerTed
Everyone needs an old chicken coop like that!  Very nice!  Glad you got it before it became a "she shed!"   :D :D
donbj
Just put a couple nesting boxes in the corner in case a chicken or two comes back home.
I may be skinny but I'm a Husky guy
Woodmizer LT40HDG24. John Deere 5300 4WD with Loader/Forks. Husky 262xp. Jonsered 2065, Husky 65, Husky 44, Husky 181XP, Husky 2100CD, Husky 185CD
Nebraska
Nice job on the chicken coop, a space like that would be really nice.
sharp edge
Its a Coupe DeVille now. :)
SE
The stroke of a pen is mighter than the stroke of a sword, but we like pictures.
91' escort powered A-14 belsaw, JD 350-c cat with jamer and dray, 12" powermatic planer
frazman
