pulp prices around
Started by lynde37avery, November 17, 2013, 09:20:06 PM
lynde37avery
whos getting what? anything not moving? seems pine, hemlock n hardwood is open in my area. 21, 27, and 30 bucks a ton trucked in. just curious. ill be getting some hemlock out I been doing some hardwood. popal  white birch etc.
Detroit WHAT?
jmouton
I've got a dumb question  but what is pulp wood  ,   we just run a sawmill  and I know what logs  and things related to cutting lumber are  but I hear you guys talk about tonnage and pulp wood but havent figured it out yet
        jim
lt-40 wide ,,bobcat,sterling tandem flatbed log truck,10 ton trailer, stihl 075,041,029,066,and a 2017 f-350,oh and an edger
ga jones
Soft wood pulp 18 bucks a ton on the landing 20 if you can load it.hardwood scrag is 30 on the landing.
380c timberjack c4 treefarmer international trucks jonsered saws. Sugi hara bars d31 komatsu 350 tj grapple
Southside
We don't have any hemlock around these parts, but pine pulp is around $30 at the mill, $21 to the broker 50 miles shorter transport, hardwood is $20 to the same broker.
White Oak Meadows
I will tell you what pulp wood is on my land. I think it has to be bigger than 4 inches,use to be just about any lenght,but longer than 4 feet,but no longer than 8 feet. Smaller than 28 inches too.Really anything that does not make a saw log. It would really be the tops of the trees,or real crooked ones that would not make good saw logs. Sold by the ton. This is used for paper making in my area.
jmouton
thanks for the info  thecfarm, it clears things up a bit
ehp
no pulp mills here , low end for me is pallet grade $325/1000 , around here if its a good log you can sell it at a good price
Corley5
$45.00 a cord on the landing for aspen and hardwood.  $35.00 for basswood.
NWP
In my area there is no pulpwood market. Low grade logs are firewood logs. I wish I could pay per ton what you guys get for pulp. Loggers around here would leave it in the woods to rot for $20-30 per ton delivered. $40 per ton average gets some into my yard.
1999 Blockbuster 2222, 1997 Duratech HD10, 2021 Kubota SVL97-2, 2011 Case SV250, 2000 Case 1845C, 2004 Case 621D, John Deere 540A, 2011 Freightliner with Prentice 120C, 2012 Chevrolet, 1997 GMC bucket truck, several trailers, and Stihl saws.
Claybraker
I just had an appraisal done and was quoted $24 a ton pulpwood, $26/ton CNS, $27-28/ton sawtimber on SYP. That's stumpage to me, the landowner. When you put a sharp pencil to those numbers, discounting back to net present value, It makes it tough. I happen to like the way the place looks with timber on it.
