Hand hewn log siding?
Started by Lone Duck, November 21, 2013, 05:48:24 AM
LoneDuck
Has anyone ever cut any lumber that was made into hand hewn log siding? I would like to put it on my home and have an idea of how it should be but any suggestions would be greatly appreciated.
Nomad
     I've resawed hand hewed timbers, but never tried to make a sawn board look hand hewn.  I'm not sure how you'd go about that.  I think what I'd do is hand hew a timber into a cant and slice the outside of it for boards.
WoodMizer LT50HDD51-WR
Lucas DSM23-19
Rockn H
The closest I've come is letting the bark slip on some pine logs.  Then level the log each time I turned it and took off a slab.  I was trying for a slab that was even and about 6"wide.  I wound up with a cant that was more octagonal then square.   I then edged the slabs to 4" wide.  This gave me a "D" shaped log siding.  I've only used this for small projects, nothing real big.    You could use the same procedure with hand hewn logs too.  You'd just have to adjust the width and thickness of the slab depending on the size of the logs and the look you wanted.  With the finished slab/siding being three sided boards basically, you could even ship lap it.
My thoughts would be to saw the cant, hew the side, and then slice it off.  I sliced the outside off of these hand hewed timbers to make boards for my Cabin Addition.
I leveled the tops so that the boards would be a uniform thickness.
Those boards then bridged the gap in the ceiling ridge between the actual timbers.
Quote from: Lone Duck on November 21, 2013, 05:48:24 AM
What is your "idea" how it should be....  ??  That will give us a better idea what you have in mind what you want in the end. ;)
LoneDuck
 Here are a few pictures off a web site and I really like the look. Like I siad, It really dosent seem real hard. Alot of hand work to get the texture look. Do you guys see a reason why I couldn't just cut 5/4 boards and do something like this? I'm looking at using cedar electrical poles as the wood. I can get tons of them. It would not be a true hand hewn  but finished it looks goog.
Carpenter
Sure, that's do-able!  Probably if you made some ax marks in the cant each time you took a board off most people wouldn't know the difference.  However, there are several of us who would know the difference.  To get the true hand hewn log look, you would have to make sure there are no saw marks showing in the finished board.  So, essentially, you would have to hand hew the surface of the cant, mill a board off and repeat.  It sounds like a lot of work, because it is a lot of work.  If you're very sloppy with a handheld planer and made a few score marks in the cant with an ax that might do the trick.  I think you'll have to do a little trial and error and see what works to get the effect that you're going for.  You have to make a judgement call here.  If you're going for the authentic hand hewn log look, then the best way to get that is to hand hew logs.  If you want the finished product to look like somebody was (trying to make the hand hewn log look with siding) instead of going to all of the trouble to hew logs.  Then, you have to ask yourself, how close to the original is close enough?
m wood
Carpenter makes a lot of fine points.  Since its siding, are you thinking of stacking the boards tight?  Something of a T&G or ship-lap?  considering any chinking?  Plywood (or something) behind?  My personal preference would be the chinking to achieve the "feel" of the hand hewn square log home look.  Then on to the corners, planning to just box them in like the 3rd picture?  IMO that could certainly work.  Sounds like a chore, but theres probably a shortcut or 2 to get that rustic exterior.  Personally, I wouldnt mind a saw mark here or there and bunch of ruffing up to dress it up, uhhh, i mean dress it down! :D.  I am about all things rustic. ;D
mark
I am Mark
80 acre woodlot lots of hard and soft
modified nissan 4x4/welding rig
4x4 dodge plow truck
cat 931b track loader
Norwood mark IV
4' peavy
6' peavy
stihl 034
"her" wildthing limber saw
ALL the rustic furniture  woodworking stuff
check out FB
Be sure and seal the board edges so that no moisture can get behind them.
Axe Handle Hound
I've used a right angle grinder with a coarse grit sanding disc to give a rustic, circlesawn look to a piece.  I was trying to match it to the trusses in a house that had been dressed with the sloppy handheld jointer technique that Carpenter mentioned.  Neither the piece I made or the trusses were authentic and anyone that had ever used a hewing axe or a circle mill would instantly know the difference, but I would think that with some practice pieces you could probably come up with a pattern/technique that you liked.
red oaks lumber
i would cut 2 1/4x10, let them dry then plane the face you want to use, then take an electric hand plane and just start scalloping the face, do the same thing on the edges. take a small axe and put some chops to give it more looks.
stain and  seal it,  put in on the walls that are already sheated with osb, start installing leaving a 1" gap between the layers.chink after complete :)
LoneDuck
Red Oaks, I to was thinking of the electric hand planer. The site that I got the picture sells the stuff but its expensive because they do everything by hand. They use draw knives and axes but I think that there are ways to use power tools sort of like Axe Handle did. I've watched some being made using chain saws but that end up looking like, well, someone went wild with a chain saw. I was hoping someone may have made some before and what they used. Thanks everyone for input. I am going to start some experimenting this weekend. I will keep you informed.
jackpine
I had a customer have me saw 2 x 8 which he then ran thru a moulder to get fake log siding. To get the more hand hewn look he then took a handheld power planer and randomly took cuts along the face. Upon close inspection it was not too close to hand hewn but from a distance did not look too bad
Bill
Bigbo1234
Your best bet is to get a good crosscut saw, fell a tree. Than use a pit saw and hand saw a bunch of boards. Done. And it only requires two tools and two steps. So simple.
Bowen
Bigbo
QuoteYour best bet is to get a good crosscut saw, fell a tree. Than use a pit saw and hand saw a bunch of boards. Done. And it only requires two tools and two steps. So simple.
Then you would call that "hand hewn"  ??
Or need to call it hand sawn?
5quarter
I would do it as Carpenter suggests. It is not that hard as long as you have the right tools and your tools are sharp and your hewn face is clear... 10-15 min per board. a heckuva lot cheaper than trying to buy it.
Bigbo...You can't hew with a saw.  ;)
Blue Harbor Refinishing
Bigbo1234
You can't hew with a hand planer either. Just a joke guys
Bowen
5quarter
Although you can hack with a saw...hand hacked timbers.  ;) :D
Some of the "factory hewed" logs that I see look like someone got to them with a hand power planer.  There are no actual axe marks.   I guess that there is a machine that irregularly gouges them with different power cutters.
They look pretty good.
Dad2FourWI
I agree with Magicman.... I was at a "cabin and lake" show and there was a vendor who sold both external/internal siding... it was very thick (~2" or more) and it looked "hand hewn"!!! It was AWESOME looking!!! A bit too $$$ for us but their product was really very nice.
I have their info filed away and could probably find it if it would be of any benefit to anyone.... let me know... just a bit of digging. :)
-Dad2FourWI
LT-40, LT-10, EG-50, Bobcat T750 CTL, Ford 1910 tractor, tree farmer
