Is anyone running 15" tires on a woodmizer?
Started by yellowrosefarm, February 19, 2014, 07:13:30 AM
yellowrosefarm
All the Woodmizers I have been around, including mine have 13" wheels. The highest load rating on a 13" tire doesn't add up to the gross weight listed on the mill trailer. Also, being lower to the ground means I have to dig a deeper hole for the outriggers and is harder on my back since I'm tall. I have a spare set of 15" rims, a tire machine and a bunch of different size used tires. Last night I tried several sizes and it seems like a 225/70/15 is the largest tire that will fit without rubbing the fender. I'm interested to know what other people are running on their mills and what was the reasoning for the little 13" tires in the first place.
BBTom
My 2001 LT40 Super came with ST225-75R15.  I just had to replace them.
terrifictimbersllc
Mine too, 225/75R15 Marathon radials on my 2001 LT40 Super diesel GVWR 4500#. On my second set with new spare.  The tire/rim from Wood-Mizer is a good deal.
yellowrosefarm
Mine is a 92 LT40. I'll go with the 225/75-15's since they are a very common trailer tire size. The 13's always looked half flat even over inflated. I sure never wanted to take it very far with those tires.
Nomad
     My spare is one of the original tires.  It's the same size as the ones on it now; 15s.
WoodMizer LT50HDD51-WR
Lucas DSM23-19
dgdrls
Currently  WM spec spares for the 40 series as 14" and 15"  with 15" for the supers and the 70 series
"Don't leave home...
You wouldn't leave home without a spare tire for your car, so why do it with your mill?
14" Silver Rim
Part no. 015987
15" Silver Rim
(For Supers, LT70 non-remote and LT70 remote AC only)
Part no. 015988
15" Black Rim
(For LT70 Remote DC only)
Part no. 04606"
Ref WM site
DGDrls
If you want to change, be sure that the bolt pattern is correct.
