fix it or replace it?
Started by woodrat, March 01, 2014, 08:47:48 PM
woodrat
I've got a Husky 51 that I bought new in 1995 and ran pretty hard as a firewood and portable sawmill support saw for many years. I was young and dumb and didn't take very good care of it, and asked it to do much harder work than it was intended to do. At one point I inadvertently ran straight gas in it, and ended up putting a new 55 piston and cylinder on it to get it going again, and ran it for years after that, too. A few years ago it started running poorly, and wouldn't idle, and bogged down a lot, and I set aside and switched to a 372XP for the mill and firewood.
Recently, I wanted to have a small saw again for small diameter alder, and the 372XP is heavy and overkill for the small stuff, so I pulled the 51 out again and swapped a used carb onto it, which didn't help, so I kitted the old carb, which only helped a little. I took it out for a couple of hours yesterday felling some small alder and it will idle a little bit now, but then dies. It bogs down and dies when you tip it on it's side, and generally had really poor power. Today I did some reading and it sounded like air leaks might be the problem. I also noticed it seemed to have pretty weak compression, so I pulled the muffler and carb to look at the piston, and sure enough, it has a big nasty black spot on the intake side of the piston, and a little scoring on the exhaust side, too, and pitting around the exhaust side of the top of the piston. So I went ahead and removed the cylinder, too.
So, I have another 55 lower end that probably has a lot fewer hours on it, that I bought as a parts saw. I think they must have ran straight gas in it, too, as it came with no top end parts. It looks like I can get a piston and cylinder for $120-150 from Baileys and get the lower mileage 55 running again.
My question is whether or not the new saws are better and lighter and cleaner running enough that I should just bite the bullet and upgrade, or is my old 55 still a worthwhile model to keep going? Looks like I could get a new 455 for about $425 or so, and all my small mount Husky bars would fit it. But it also doesn't look that much lighter weight, either. And if I do decide to rebuild the 55, should I plan on new crank seals right off the bat, since this has been sitting around in the shop for several years?
1996 Woodmizer LT40HD
Yanmar 3220D and MF 253
Wallenstein FX 65 logging winch
Husky 61, 272XP, 372XP, 346XP, 353
Stihl 036, 046 with Lewis Winch
78 Chevy C30 dump truck, 80 Ford F350 4x4
35 ton firewood splitter
Eastonmade 22-28 splitter and conveyor
and ...lots of other junk...
Timberjack_395XP
Have seen excellent  55s lately  going in southern Indiana around $125 tough for me justifying rebuilding a saw when you got deals laying around  i keep my rebuilders for part saws
woodrat
The tend to go for $200-300 around here. If I could pick up a clean 55 for $125, I would jump on it.
I'm leaning towards fixing this one.
