Number of resharps before breaking?
Started by Ocklawahaboy, May 06, 2015, 07:43:12 PM
Deese
QuoteWhen I set it to just take a light grind, it will miss some teeth. I end up setting it to take a little more off than I like, just so it's hitting everything.
Same Here.
2004 LT40 Super 51hp w/6' bed extension
Cooks AE4P Edger
Cat Claw sharpener/Dual Tooth Setter
Kubota svl75-2 skidsteer w/grapple, forks, brushcutter
1977 Log Hog Knuckleboom loader/truck
losttheplot
Quote from: Deese on May 08, 2015, 02:50:43 PM
Same Here.
Mine does also. some times its burning the teeth and others its not touching them.
I put some silicone on the metal plate that the side of the pushing "paw" rides against.
This seemed to help some.
Also the spring that is attached to the pushing rod was causing it to twist.
I stretched out the spring a little.
I have some new bands to sharpen and I will see how it does.
DON'T BELIEVE EVERYTHING YOU THINK !
