Nyle 200 Kiln Chamber?
Started by WillWarner, June 04, 2014, 05:54:58 PM
WillWarner
Has anyone ever used a 20' reefer box for a kiln chamber?  I have found an older reffer box in good condition pulled off the truck and the refrigeration unit has been removed.  I am thinking about converting it to a kiln chamber for my Nyle 200 but am worried about corrosion and such. Any input?
Ephesians 2:8-10
GeneWengert-WoodDoc
NYLE has some instructions for how to do this.  It works well.
jdonovan
I know a guy who did it... he had one comment. Next time it will have a cart & track system.
Having to carry each board into the chamber to load, and then out to unload is a big pain he said.
Missouriwildman
I am considering almost the same thing. I have access to a 20' metal shipping container. It's the kind they use on ships to ship overseas. It's completely steel with waterproof plywood on the floor. The doors seal well and nothing leaks. I was thinking about cutting a hole in the side of it and install a kiln. You guys said nyle makes one? I'll have to look that up. Any suggestions?
On order Timberking 1600 , 25 hp diesel, TK blade sharpener and setter. JD 5210 with 540 loader and 5 ton Braden 3 point winch for skidding timber. Bobcat S160 turbo hi flow with loader forks. Chainsaws ms 200t , ms 210, ms 250, ms 390, can't hook, Log waggon and other stuff..I love stuf
xlogger
Does anyone here have a picture of a cart and track system that they use on the shipping containers like you where talking about?
GeneWengert-WoodDoc
I found these great pix from Bill Stuewe of Bill's Woodshop, Sawmill and Lumber in Georgetown (near Austin), TX.  you can see more at
billstuewe.wix.com/billswoodshop#!sawmill
