Chainsaw outboard motor 2 in 1
Started by d1hamby, July 29, 2014, 10:46:04 PM
d1hamby
Own a Stihl 362 16" 0.050" carbide and steel, and 25" 0.063" Stihl 020T
Stihl KM131R, 130R and KM56R with several Brush Cutter and Weed Trimmer heads. Pole Pruner (with 10", 12" w/wo Carbide, and 16" bar&chains) , Blower, Modified 135° Hedge Trimmer, Straight Edger, Bed Edger, Tiller Kombi attchment
r.man
I knew an older man who used to swap out one motor on his snow blower and garden tiller. If the switch over was easy you could greatly cut down on the number of small motors needed in a household. I have thought tiller, wood splitter, snow blower and lawn mower would be examples of machines that could use the same motor if the shift over time was short and easy.
Ljohnsaw
Had a little trouble understanding him  :D
Pretty good idea.  Wonder if its an off-the-shelf item over there.  From the looks of the prop, he seems to be using it a lot but could use a little down trim on the boat.
John Sawicky
SkyTrak 9038
Ford 545D FEL
Genie S45
Davis Little Monster backhoe
Case 16+4 Trencher
36 coupe
Quote from: r.man on August 05, 2014, 11:52:16 PM
The Toro Power Handle did that 50 years ago.I had the mower,tiller and snow snow blower.Sold the outfit long ago.
stumpjumper83
Neat little gizmo.  Might work be about right for a canoe.  As it is if he brought lunch with him it might capsize the boat.
John Mc
DR Products makes something like that now. If I recall, you can swap a mower head (or was it one of their walk-behind brush mowers?) and a snowblower.  The snow blower was only single-stage, however, so I never seriously looked at it.
John Mc
Seems like it might develop problems if operated extensively at partial throttle settings, since a chainsaw engine is made for either idle or WOT. Hopefully the prop provides enough of a load to prevent over-speeding the engine at WOT.
mad murdock
Those rooskies are pretty darned innovative!  That is a cool looking attachment for a sawhead 8)
