Onan valve keeper install? HELP!
Started by Delawhere Jack, August 22, 2014, 06:04:33 PM
Delawhere Jack
Trying to reinstall the intake valve on an Onan P224, exceeding the MDPH (Maximum DanG's Per Hour).  >:(
Any tips? Any special tool to hold the keeper in place while you release the spring?
BCsaw
We used to use grease! Not sure if the Onan is the same as conventional 2 piece keepers.
Inspiration is the ability to "feel" what thousands of others can't!
Homebuilt Band Sawmill, Kioti 2510 Loader Backhoe
Delawhere Jack
BC, yes, they are conventional keepers. The problem is lack of space to work, they're in a really tight recess in the casting. I've been using hemostats to place them. There is not enough room to put them in by hand, and I'm a little wary to try. One slip of the compressor and instant finger ground meat...
BCsaw
Thats the challenge to try and get them stuck in place, then get fingers and tools out of the way. I always recommended to put shop rags or something over top to catch parts if they did not catch properly. Also, give the end of the valve a tap with a dead blow or soft face hammer once you have released the compressor to ensure the keepers are intact.
Good luck.
North River Energy
I've placed tricky keepers with a blob of grease on the end of a curved dental pick.  And also walked one keeper around from the easy side of the valve stem to the side with poor access. (Not on your motor, but on others with tight work clearances).
sawguy21
That is how I did it. I also learned to stuff a paper towel in the oil drain back hole on the horizontal twins after dropping a keeper ::).
biggkidd
  A small pickup magnet is your friend here. Done it many many times.
Larry
Echo 330 T, Echo 510, Stihl Farm Boss, Dolmar 7900, Jinma 354 W/ FEL, & TPH Backhoe, 1969 M35A2,  1970 Cat D4
Building a Band Mill  :)
Delawhere Jack
Quote from: biggkidd on August 22, 2014, 10:33:46 PM
Larry
That's what I was thinking. Maybe two of them, handled like chop sticks...
Grandedog
Quote from: sawguy21 on August 22, 2014, 09:49:44 PM
Howdy,
   Sage advice on plugging the hole.
Regards
Gregg
Gregg Grande
Left Coast Supplies LLC
1615B South Main Street  Willits, CA 95490
888-995-7307  Ph 707-602-0141                   Fax 707-602-0134  Cell 707-354-3212
E-Mail  gregg@leftcoastsupplies.com   www.leftcoastsupplies.com
Andries
Any chance of a few photos?
I'll be doing the same thing this winter and the talk of hemostats and magnets has me scratching my head.
Thanks in advance . . . .
LT40G25
Ford 545D loader
Stihl chainsaws
