3 Point log Grapple
Started by akpilot, September 27, 2014, 08:33:16 PM
akpilot
I needed a more efficient way of dragging logs out of the woods and to try to keep them fairly clean in the process, so I built this grapple for my 40hp New Holland seems to work pretty well and it's surprising how much it will pick up without lifting the front tires.
fishpharmer
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
Peter Drouin
A&P saw Mill LLC.
License NH softwood grader.
NHMike
That is a really nice grapple.  You have great welding skills.  Looks pretty beefy so it will last.  What do you guess the weight lift limit to be?
r.man
Nice looking rig, how did you decide the distance from the grapple to the three point?
21incher
Nice job. Were the parts CNC plasma cut?
akpilot
Thanks for the kind words...
NHMIKE...Not sure how much it will lift, it will carry a whole 10/12" 30' Birch tree with no problem... which suprised me!
r.man.... I would like to tell you how smart i am......but i'm not!! I had 10' of tubing cut the bottom cross bar, the riser and used the rest on the boom, which came out about 5.5'
21incher.... Yes I have a small CNC plasma table and I do my own Powder Coating!
gspren
DeerMeadowFarm
ckhenshaw4
WOW, that is very nice!!!!!!!
Getting TOO old to "man handle" wood anymore. Looking at building a firewood processor.
