- what real 2 stroke engine parts look like -
Started by BargeMonkey, September 03, 2014, 01:36:15 PM
BargeMonkey
 Stuck at work again with some serious issues on the Port M/E, figured I would post some pics. Next week hopefully back in the woods.
Thats a 2000hp 8-710 EMD, hopefully we will know tomorrow if we have to rip the whole front end off or not.  :D
LeeB
You could have 16 of em to do. Look on the bright side. The rig I'm on now has Cat's. I kinda miss the rumble of the EMD's.
loggah
Bargemonkey, i thought you might have driven over one of your chainsaws with the skidder !!!!  ;D Those big old engines are pretty neat, i know Fairbanks-morse made a bunch of them ,O.P. models used in subs and whatnot !!!
Interests: Lombard Log Haulers,Tucker Sno-Cats, Circular Sawmills, Shingle Mills, Maple Syrup Making, Early Construction Equipment, Logging Memorabilia, and Antique Firearms
BargeMonkey
 Got the whole front end torn off today, the welder is coming tomorrow, and setting up his milling machine for the block repairs. Im leaving this in more "qualified" hands come monday morning thank god.
There are still a few 8-1/8 Fairbank Morse engines around, was on one this summer in Troy NY, few of them still running the canal. An OP takes some time to wrap your head around.
ozarkgem
BargeMonkey
Just 1 per cylinder. Thats a unit injector, I dont know what a 710 factory one costs, I know a 645 eco injector was 1200 a few years ago, probably double that for these.
Thats Mike, milling down the block face. He travels all over the world just welding and machine work on these engines. I posted these pictures because these are basically a detroit on 100x steroids. Same principal.
tj240
thats one big motor jim mckee may have spelled his last name wromg used to work on tug motors probably not that big tho
work with my father[jwilly] and my son. we have a 240 tj 160 barko[old] works great three generations working together
ozarkgem
Quote from: BargeMonkey on September 07, 2014, 08:13:44 PM
I bet Mike makes pretty good money doing that. Any close ups of what he is doing.
BargeMonkey
    he had to weld up the section where the cam stub bearing retainer goes. She broke 2 bolts then started a chain reaction of destruction. My relief caught it before it got bad. Yeah he was telling me about being in Romania this spring doing a boat.
   he has a magnetic mill, did a nice job.
   thats my home away from home.
   A couple of the boats sitting across from us. Ive gotta find more time to get better logging pictures, the boats I have plenty of time to goof off.  :D.  You would think with people still out of work we could find employees who last, we go thru deckhands like toilet paper. 400 a day, and paid vacation for the winter and they just dont make it.
ozarkgem
I never heard of a magnetic mill and I have owned a machine shop for a long time. Must be sort of like a mag drill. I guess everything he welded up was cast iron. Remachined the bearing hole and the surface around it. Very interesting. How long did it take him to do all of that?
BargeMonkey
 It was a smaller mill with a large magnet on the base, had a seperate power supply for the base. He welded on it slowly over 1.5 days, to not distort the block. Unless im wrong, that block started life as a few chunks of steel, nothing cast on the block itself. EMD made 12 of those engines during WW2 made entirely from stainless steel for the navy minesweepers. Im finally getting to go for the next 2 weeks of training on these in January, should be lots of fun.
UN Hooker
HMMM  That looks like a " Climax Portable Boring Bar" -  A real handy tool to have in the tool box.      UN
Retired Toolmaker/Moldmaker
C-4 & C5D TF - 5500 Iron Mule - Restored 4400 Ford Ind. FEL ex Backhoe w/custom built boom w/Valby 360* grapple w/18' reach - 920 Cat w/bucket & forks w/clamp - Peterson 10" WPF - LT-15 - Cooks Catsclaw & Dual tooth setter - many Husky saws
