Woodland Mills Speed-SFP questions.
Started by Paddydiver, September 09, 2014, 05:54:56 PM
Paddydiver
Hi Everyone. Me again asking another silly question.
I'm a tinkerer at heart and don't want do do anything stupid to my mill.
I did some digging and found that my mill only runs at about 2900SFPM(Surface Feet Per Minute).
I have been looking into timber wolf blades and they say their blades are rated at 5700SFPM. So my mill is running a lot slower than what they suggest and I think its prematurely wearing my blades.
My question is has anyone had any experience with increasing the drive pulley wheel to increase the speed of the mill?
I realize I would have to cut part of the shield away to accommodate a bigger pulley but that is something I'm willing and able to do easily.
Any thoughts are welcome.
I sure don't know. But I do know there are a few members with a Woodlands mill. They have not mentioned problems with the band speed. Also if you speed things,any bearings might have to be replaced with ones that could take the increased speed. And maybe your mill is not designed to run at a faster speed at all. Kinda like having a car that will do 120mph. Just because it can,don't mean you have to drive it that fast. Timber wolf probably have that speed stated for the bigger mills.
goose63
I am happy with the band speed on my woodland
goose
thank you to all the vets
drobertson
Just reading this, and have to say, if you want to tinker go ahead, but it might have been better to have known this ahead of time. as mentioned, these mills have produces a pile of lumber, if you want or need more speed you might consider going bigger rather than cobbling(no disrespect intended) a workable mill.  On the flip side, you very well could uncover an aid that would actually work.  Just saying most of the mills on the market are designed, so this could be a head ache in the long run.  How knows, not every design is perfect.
boscojmb
The advantage to your mill is that it is light weight and can be set up in places that other mills can't.  8)
In round numbers, if you double your band speed, you'll need 2½ times the power to run it.
Increasing your band speed and adding a much larger engine may or may not be an advantage.
I think that the folks at Woodland matched the band speed to the engine.
John B.
Log-Master LM4
Paddydiver
These are all things i have wondered myself. I guess the big thing I'm just wondering if running blades at half their intended speed dulls and or damages the blades? And would even a small increase in band speed increase production?
If running a manual mill,a slow speed is not a bad thing. You get less done and less logs and cants to turn by manpower.  ;D  I have no idea how fast mine turns. Fast enough,I guess,it gets the job done,at a walk.
boxygen
If you change  the size of the pulley, you will change the speed of the bandsaw, but you will need more power to push it. Perfect analogy is riding a bike in high gear and low gear. If you want faster, you need more power. There is no free lunch here. The engineers knew what they were doing when they designed it.
Hudson Oscar 121. Mahindra 2415, fransgard winch. Husky chainsaws from 346xp to 394xp, most are ported.
