Help for a new video for beginners at the mill.
Started by Wolfgang Rother, April 09, 2023, 02:48:38 PM
Wolfgang Rother
Hi all i am thinking aboút 5  or more tips for Beginners.
Like don`t cut twisted trees.
Don`t cut thing material when the tree have too many and big brunches. (sry for my english)
I hope u see my point.
Thanks for help.
Danke
Wolfgang
DanMc
I'm looking forward to seeing the video.  Put something together.  That will spur on people to make suggestions for more helps.
One recommendation is:  Always check your log stops before starting the cut.  And, check for log stops that might be sticking up beyond the log.  I once hit a stop right after changing the blade.  Then after putting a new blade on, pushed past the log and hit a stop that was sticking up.  Two new blades in two cuts.  That was so painful.  I figured I should just quit for the day before something worse happened.
LT35HDG25
JD 4600, JD2210, JD332 tractors.
28 acres of trees, Still have all 10 fingers.
Jesus is Lord.
fluidpowerpro
Never saw naked.
(no need to cover in a video!)
Change is hard....
Local wind direction is determined by how I park my mill.
JonathanPace
The guys from Norwood Portable Mills make rather good videos like this one:
https://www.youtube.com/watch?v=3CrLvbqNpQg
I'd love to see a blend of technical do's and don't paired with a bit of humour to keep it interesting, and not drawn out either. Can't wait to see your video mate!  8)
Nebraska
Look twice saw once... I relearn that one every so often
Redmt
Make it to the point. You don't need panoramic views of the country. You don't need dramatic lead in music. Make sure your audio is clear of major background noise.
Those who would disrespect our flag have never been handed a folded one.
DanMc
Speaking of background noise, DO NOT suppress the sound of the mill with music.  We want to hear the machine!!!!
LT35HDG25
Jesus is Lord.
Ventryjr
Quote from: fluidpowerpro on April 11, 2023, 02:32:26 PM
Never saw naked.
How else do you become one with nature??? Haha.  Good suggestion.
-2x belsaw m14s and a Lane circle mill.
SawyerTed
Looking back, my biggest beginner issues were around trying to continue to saw with dull blades.
Some things to consider for beginners.
Blades are consumable.  Don't expect blades to cut more than a log or two (beginners).  Start with a supply of sharp blades.  The one that comes with the mill will get dull.
Waves come from dull blades, too fast sawing, build up on the blade, lack of sufficient blade tension.  Check these BEFORE tinkering on the mill.
Have a plan to stack and sticker lumber and get rid of waste slabs.
Mister Miller
The manual is your best friend.  The original engineers know best!
Checklists are your friend.
Just like flying planes and painting, most of the work and time is spent during the planning/preparation phase
Woodland Mills HM 130 Max portable sawmill with extension
