Simple set issue
Started by Bruno of NH, May 21, 2021, 12:20:15 PM
Bruno of NH
My simple set won't work while the blade is engaged.
Works fine when not.
Any thoughts ?
I'm to busy for this   :D
Southside
Sounds like a loose connection and the vibration is bringing it to the surface.  Does it shut off or just not go up and down?
White Oak Meadows
Bruno of NH
Southside
When is the last time you greased the rocker switch?
White Oak Meadows
Crossroads
Does it say up or down when you move the drum switch? I had trouble with mine recently and it ended up being bad brushes at just over 500 hours.
Bruno of NH
I greased the rocker switch last week.
It will say up and down
Works fine with the auto clutch off
Quote from: Bruno of NH on May 21, 2021, 12:20:15 PMMy simple set won't work while the blade is engaged. Works fine when not.
This could indicate that your have a wire loose/broken that is making contact while the clutch is disengaged and opening when clutch is engaged and the motor rotates.  That movement could be opening a connection.
Those troubles are tough to locate.  Running a temporary "jumper" wire will often isolate a broken/loose wire.
Wood-Mizer tech support will help you isolate the problem.
Bruno of NH
Checked all the wireing and couldn't find anything loose or pinching.
Did tighten my brake a little and put on a new set of roller guides.
I will call woodmizer tomorrow.
And all the test lights on the simple set are working
