Bandsawmill deck hight
Started by Brandon1986, October 18, 2014, 04:23:46 PM
Brandon1986
Hey I am working on building a mobile bandsawmill. I need to know the deck hights of a few brands to know what to set it at. Right now I am looking at 30-32" is this higher than most or is it a good elevation to work off of.
Thanks in advance y'all
goose63
Mine is 28''
  Kal is ten and he has no trouble helping me run the mill
goose
thank you to all the vets
drobertson
keep it low, maybe 24" a little more, that should work,
A little above your knee whatever that works out to be. Many times the axle and tires you have will determine the exact hight. Frank C.
StimW
I built a frame so I can put an axle under mine to move it. I found it easier to use with it on the ground.
I seem to spend a lot of time going back and forth around the mill setting up and/or removing cut boards.
Low makes loading logs easier too.
My push bar is the perfect height like this.
New HF Band Mill
Branson 35 hp 4 WD Diesel Tractor W/Attachments- Backhoe, FEL W/ Bucket or Forks, 4' Tiller
4000# Clark Forklift W/24" Tires
Promark 6" Brush chipper W/18 hp Kohler
Brandon1986
Thanks for the help y'all I will post pics of all of my home made abomination's as they get finished.
