Need help with track on a 00 frick
Started by Wykert82, November 08, 2015, 02:13:21 PM
Wykert82
I'm setting up a 00 frick and I have the track level but the cirage is high on the blade side by a half  inch it's like the wheels don't adjust for the rail on the track I have never run in to this should I raise the flat side to adjust it or do I do something to the cirage
Welcome to the Forestry Forum.
This pub'n may be of interest to you.
http://www.fpl.fs.fed.us/documnts/misc/circsaw.pdf
And click on your forum name and it will take you to where you can put your location in to your profile. Will help with answers for you.
Wykert welcome, tell us more about the mill are all the parts from that same mill.?? Shims are a sawyers friend. If everything on the carriage looks good and the wheels aren't just worn out probably putting a half inch under the low track is the easiest. Are your tracks mine rail or some other shape.?? Frank C.
dblair
where the drive comes from the husk and to the cable drum drive it should be an alignment point ,as I hope this is the same as mine, this sets the height of the rails and should set the height of the carriage .
old Appomattox Iron Works circle mill.
Wykert82
It's all the same mill it was in1953 it was used very little it is on original wood and it has oval head rail
