Thanks to Peter Drouin for his help
Started by POSTON WIDEHEAD, March 02, 2015, 07:23:36 PM
Brucer
I use the poly with buckles to band up my slab bundles (for sale as firewood). It's amazing how much abuse it can take. I don't ship out much lumber or timbers but the few times I have the poly strapping made things much, much easier.
Bruce    LT40HDG28 bandsaw
customsawyer
I got the banding a while back and it sure makes things nice.
www.thecustomsawyer.com
justallan1
What size strapping are you guys using? On 8' I've made full units, but on 16' I'll only be able to make 1/2 units because of weight. Any recommendations are appreciated.
Allan
terrifictimbersllc
I've used orange Kubinec 3/4 poly strapping with buckles and a very simple tensioning bar, when the customer needs strapping done.  Industrial results. Got these strapping supplies here, Bailey's sells them too....
http://www.ptipackaging.com/packaging-supplies/strapping-supplies/woven-strapping-tools/kubinec-tension-bar.html
PineNut
I use the poly straps and buckles. Since the straps and buckles can be reused I will band anything that is to my advantage. I stick and band slabs for firewood.
hackberry jake
We use the crimp sleeves at work. We use a pair of channel locks to squeeze the sleeve in place and then come back with the crimpers. Much easier than trying to hold it in place.
landscraper
Quote from: justallan1 on March 04, 2015, 06:44:08 AM
Allan
1/2" & 3/4" poly, I bought some from Uline, some from a local pack&ship store who ordered it in for me.
I use the 1/2" for odds and ends, stake bundles, small mixed orders, I use the 3/4" for the full hacks of material.  I use a combo hand ratchet/band cutter that tensions and cuts off the loose end.  I think it will tension and cut up to 1" wide strap.
Firewood is energy independence on a personal scale.
Brucer
I use the 3/4" strapping. I tell me firewood customers if they cut the strapping next to the buckle, I can re-use the strap and the buckle. Most of them bring back the used straps when they come for another load. That's the big advantage (for me) of using buckles -- I can keep re-using them.
I started off with the simple lever tensioner. Once it became obvious that this was the best way to bundle my slabs, I bought a ratchet tensioner so I could get the bundles tighter.
