Gonna miss your OWB 'til next fall?
Started by doctorb, April 03, 2015, 06:49:20 PM
DeerMeadowFarm
I think I'm going to shut down this week. Supposed to be in the mid 60's during the day and 40's at night. I just found out I am most likely going to need surgery on my left elbow. I am going to put it off until I can get my wood done for next year. I'm about half way there now if I stop burning now. I have about 1/3 of what I need dropped, I just need to split and stack it.
I have shut the heat off in the basement,just heating the living area. I have not turned the valves off for the heat yet. I am not burning much wood now. Temps are in the 60's at high noon.
Farmerjw
We burn ours year round.  Wife likes the heat and if she opens a window in the afternoon, who cares.  Soon we will have the valves turned off and only running to the hot water heater.  With just the two of us we build a fire every other day or so to keep the hot water hot.  Like others have stated, it is a way to burn the sticks and assorted junkier wood.
I am envious of the wood shed and covered stove!  Wow!
Premier Bovine Scatologist
Wick
Good Thread, nice shed.
I will keep mine going intil it gets too aggravating to keep the coals hot. So far so good with temp's ranging from 70-80's. I open the door to allow air to rejuvenate the fire (and check the wood supply) every evening after work. Haven't tried adjusting the T-Stat. I find this time of year the slabs work great.
Have turned the pump off which sends water to the heater coils, now just supplying hot water.
Timber Harvester 30HT25
DeerMeadowFarm
"Officially" switched back to Oil last night.
petefrom bearswamp
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
JJ
Stopped when wheel barrel started leaving ruts in lawn (mud season arrived)
   JJ
lopet
They're calling for single digit temperatures again the next week, will just keep on burning for another 10 or 14 days.  ;D
