Finally! A Yard Tree Without Metal.....
Started by WDH, July 21, 2015, 09:02:39 PM
Jim_Rogers
The logger brought me this dead standing pine log that I needed to get some wide boards out of and it was showing a metal stain on the butt end grain.
I sawed on it for a while to get it down to a reasonable size and then took a chance and sawed on the face where the nail was:
It took a while for the metal detector to read the nail but it finally did and with a couple of chops with the axe I found it.
And was able to pull it out without chopping the head off the nail.
As the log was 12' 10" long, I was able to saw off the chop spot and still get a 12' 4" board for the order. I really lucked out on that.
Jim Rogers
When you are dealing with metal in logs, luck counts.   8)
PineNut
Several years ago my brother-in-law wanted me to cut a mantle from a cedar tree. The tree was about 10 " in diameter and came from a location near the house and right beside the driveway. From the location, I was sure there was sufficient metal in the tree to make a run to the scrap yard worthwhile. Metal detector couldn't locate any metal and I figured it wasn't working. So cautiously, I began the cut. I did not find any metal at all in the tree. That must be one for the record book.
Kbeitz
I don't beleve it...
I bet someone planted it there...
Love machine shop work
and Wood work shop work
And now a saw mill work
