Pecan Pies
Started by Magicman, July 20, 2015, 07:35:51 PM
petefrom bearswamp
Tammy, you said pies did you have more than 1 piece?
Pat this was the best as I told you at the table.
If Linda and i can stop by for a visit I may try to cajole you into making one.
Lynn, I have been practicing the pronunciation and I now have it to p'caan
Pete
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
BradMarks
That there is the correct pronunciation.  And those tasty reviews from the Pigroast!!   Can I order up a pie, some blue crabs, and a Jax tray of crawfish please, just enough for two people so they don'y go away hungry 8)
Quote from: petefrom bearswamp on August 03, 2015, 05:22:51 PMLynn, I have been practicing the pronunciation and I now have it to p'caan.
Wrong.  When you are talking about PIES you should not want to mess with the cook.  She says Pecan Pies are correctly pronounced as she instructed you.......   ;D   :)
pappy19
2008 F-250 V-10
2007 Lincoln LT
1996 Ford Bronco
Kubota 900 RTV
Shindiawa fan
DANg!!!!!!!!
When I went through the line, they was all gone.  Poston had even licked the aluminum pie tins  :'(.
Of course, the correct pronunciation is "Pee-Con".
Most folks that cannot pronounce correctly also can not see well.  The pies not in aluminum pie tins.  They were in clear glass Pyrex pie dishes.   ;D
petefrom bearswamp
Lynn, Ill keep practicing.
Kubota 900 RTV
OK, so I need another chance to ID the container properly and redeem myself, so I suppose that you must certainly commission Pat to make some more.  There, it will all work out in the end, and the mis-identified containers will not get offended.
You indeed are a very wise man....very wise.  But of course customsawyer wanted to know "where were the Coconut Pies" ??
