Safety tips please
Started by outpost22, November 20, 2015, 02:57:08 PM
Chuck White
For removing the sawdust from the cut so you can back out of it, I would suggest that you remove the set from the length of blade you're using!
Just makes it easier to use, and still just as effective!
dustintheblood
Make sure you get paid, and the check clears.  Not safe for your own heart and blood pressure if you don't.
Case 75C, Case 1494, RangeRoad RR10T36, Igland 4001, Hardy 1400ST, WM LT40HD, WM Edger, ICS DH Kiln
dustintheblood
Now this is a GREAT idea!!!!!
Quote from: Andries on November 23, 2015, 12:17:45 AM
Quote from: nomad on November 21, 2015, 10:54:37 PM
     Lots of people use a broken band with a bit of duct tape around it to clean sawdust from behind a stuck band to back it out. A drywall knife is great for cleaning sawdust from boards and cants.  Must faster and cleaner than a broom.
My duct tape and broken band went through my gloved hand one day. (as if a broken band mid-log isn't enough to make a guy grumpy) So, I got all arts and crafty and made this up:
Make the blade long 'nuff to reach through your biggest cut possible.
. . . and if nobody is watching, you'll feel like a Ninja Sawyer when you swish it throughout the air.
not that I've ever done that . . .
