How much lumber in a truck load
Started by Horselog, February 21, 2016, 08:44:12 PM
Horselog
How much green lumber does an average tractor-trailer haul legally?  I know it will be different depending on species, I'm looking for numbers for both lighter and heavier species (eastern hardwoods).
Benjamin Harris
Appalachian Mountains of Virginia
horse_logger@me.com
Use the Toolbox in lower left column, and you can figure weight of thousand board feet, and knowing the truck limits, get your answer.
https://forestryforum.com/board/index.php?action=toolbox
YoungStump
It depends some on the type of lumber, for example you can't get as much footage on a load of 4/4 lumber as you can on a load of blocking or ties because every board is 1/8" heavy but only figured as 1". Here recently I sent around 7200' of beech 4/4 and was right at the limit and 8500' of ash 4/4 and 7/4 that was right on too.
Echo Enterprises 45HD2 production series band mill, Cook's Edger, sawing mostly pallet cants, rr ties, and grade lumber.
sandsawmill14
we put about 10000 bdft of poplar and 7500-8000 bdft of oak or hickory :)
