Larch Question
Started by west penn, April 01, 2016, 06:42:22 PM
west penn
  I just put a load of larch in my kiln--nyle 200.   pretty much green, 26 to 40 MC  about 1800 ft. I have a setting of 70% at 100 degrees and humidity in kiln is 88%.  Am I on track ?   any other suggestions?   I dont want to turn this into pretzels. I know how larch can react.  water is really coming out. the kiln floor was cold and is soaked.     Thanks for any info.
bkaimwood
You do not have an updated profile, so I have no idea where you are from, but am going to go out on a limb and say western Pennsylvania... I can't help you with your question, but thought maybe you can help me... I recently sawed a tamarack log, otherwise know as larch? It had the worst pitch of anything I ever sawed, including reclaimed heart pine beams...to the point it was almost unsawable... Is this common, or did I just have an isolated incident? It also seems to have spriral grain?
bk
west penn
 I haven't sawn a large amount of larch,( I believe tamarack is the same, looses it's needles in winter)   some had a lot of pitch   others not so much.  It does have a spiral grain and can be prone to twist  but weathers well. I made some paneling for my brothers porch and it turned out great and looks great also. Larch is not really native to my area. What I have sawn came from a planting and were straight and tall with small knots so might have made a difference in the outcome.
barbender
     I have sawn tamarack that sawed very nice, and stuff that moved so much on the mill I couldn't get a 2x4 out of it. And yes, it is pitchy. It is also very strong, and moderately  decay resistant. I have also noticed it has a tendency to check right across the grain when air drying (I don't have a kiln).  I would guess that you would need to slow down the drying process in comparison to other softwoods, but, it is just a guess ::)
That may be too big a load for a fast drying softwood like tamarack.
west penn
  Do I need to turn the setting up to 100%?   What would be the ideal humidity to try to maintain?
I would do that with green pine.  I suspect that it will be the way to go with tamarack, too, given the amount of BF in the kiln. Most softwoods dry fast and can stand the 100% compressor run time.
