Old Husqvarna and ethanol gasoline
Started by Mikeinkaty, June 14, 2016, 03:13:43 PM
Mikeinkaty
When ethanol gasoline first came out it pretty quickly turned my gas line to jello!  A new line fixed that problem.  But, that was like 20 (?) years ago.  Been running ethanol gasoline ever since.
Last month I found a station in Oklahoma that has no-ethanol gasoline so I got some and tried it.  Man, what a difference!  My old Husky white-top 61 runs better and has more power!
I assume newer saws have been optimized for ethanol gasoline?  Is that correct?   Can they still run with straight gasoline (no ethanol)?
Mike
DDW_OR
everyone i have talked to that use 2 cycle engines prefer non-ethanol
Al_Smith
I'm not so certain it would make much difference in how it ran .It would however make a difference in how long the seals and carb parts would last.
I will add it takes 40 more percent by volume of ethanol to equate to straight gasoline or so I'm told .Then too you have adjustments on the carbs and perhaps a little turn here and there you might not be able to tell the difference .It is something to talk about though ,somewhat akin to the great oil discussion . ;D
gspren
   A friend/neighbor that does a lot of crabbing with a small boat and 9.9 HP 2 stroke outboard says a 6 gal can of non-ethanol lasts almost 2 hours longer than ethanol gas.
Czech_Made
You can look up pure gas stations in your area here:
http://www.pure-gas.org/
Walt
Ethanol mix gas will sour in a couple months, I have had carb problems time and time again from equipment setting gassed up with ethanol blends. I can't tell much of a difference in performance but we recently moved to an area where I buy ethanol free premium. No more stale gas in our stuff...Its ethanol free for me...
BTW, our local Stihl dealer has a list of gas stations that sell EFG...
MS461R, MS290, MS170, Homelite XL, Dirty Hand Tools 27T splitter, Kubota B20 FEL&BH, Timberjack Woodchuck, US Stove Co. 2421 for heat. Too many Wheel Horse Garden Tractors..
SawTroll
Quote from: Mikeinkaty on June 14, 2016, 03:13:43 PM
Mike
I don't think so - but newer fuel lines etc usually tolerate it better than older ones.
As far as I know, what works best in most modern chainsaws is alkylate fuel with high quality fully synthetic oil - and that is what they are optimized for, to the degree they are optimized at all.
I suspect the same stuff works best in older chainsaws as well, and with that oil you can just forget any 25:1 or 16:1 mix ratios.
An older saw that has been run with a high content of dino oil in the mix and/or a too rich carb setting needs to be cleaned before using alkylate fuel in it though. If not, flakes or lumps of carbon deposits may come loose and create trouble.
Information collector.
Canadiana
Quote from: Czech_Made on June 15, 2016, 07:38:14 AM
Excellent post, this site could not be simpler. Thanks Czech_Made.
The saw is more fun than the purpose of the wood... the forest is trembling 🌳
