Homemade Bandsaw Sawmill Pic.
Started by jssmitch, November 01, 2012, 10:05:21 PM
jssmitch
OK, as promised, go to my gallery for all my pictures making and operating my Homemade Sawmill.  Sorry, I have not figured out how to post to the post yet.
Jessie David Mitchell
USN Retired
Homemade band mill/Bought TK1400
The hard part is done once you have them in an album
Click onto your album,click onto the picture you want,it will get bigger,scroll down a little,will say Insert Image In Post,click onto that,say yes, and that's it. click onto preview to make sure you want it. I like to hit the enter key once or twice to bring the picture away from the post. The enter key also helps when posting 2 pictures back to back. It leaves some white space between them.
Looks good. I always like to know,what's the plan for all of the lumber? have your own trees?
barbender
It looks like you did a great job. I have to add one thing, get some guards around around that blade.  ;)
customsawyer
www.thecustomsawyer.com
pineywoods
+1 on the guards. I would assume you ain't broke a blade yet..scary.
tcsmpsi
Yes on the guards.  Well, there were still plenty of trees over in Dayton when I was there the other day.  :)
\\\"In the end, it is a moral question as to whether man applies what he has learned or not.\\\" - C. Jung
Hilltop366
jssmitch
In response to all, I have my own trees to a point, and my wife has plenty of honey do jobs to take up all the lumber.  Just mainly trying to keep myself busy.
Yes, I intend to put blade guards on.  I had to get the bugs out without having to redo to much, but now that I know it runs without much problems, I will be starting on guards, then some stout rails under the base so I can just drag it around and not have to worry about how solid the base is before I load a log.
I have found a few things that I want to change a little, so next week I plan on putting it back in my shop and do the changes, like a 12V winch to raise and lower the blade and a more stable/stout tension system, then the guards.  Just wanted to let everyone see what is happening this far.
USN Retired
Woodchuck53
Great job. Is it your own follow on plans or did you do some from scratch? I want one but have way to much invested in the circle mill rebuild to think about it now. Maybe one day.
I think the guards ought to be priority one tomorrow morning. Less chance of trying this or that after a mod. and getting hurt. I think from the gist of this forum we all work mostly alone and some may not make it in the event of an oops. Stay safe fellows I have a lot of questions yet. Chuck
Case 1030 w/ Ford FEL, NH 3930 w/Ford FEL, Ford 801 backhoe/loader, TMC 4000# forklift, Stihl 090G-60" bar, 039AV, and 038, Corley 52" circle saw, 15" AMT planer Corley edger, F-350 1 ton, Ford 8000, 20' deck for loader and hauling, F-800 40' bucket truck, C60 Chevy 6 yd. dump truck.
jssmitch
Chuck, to be honest, I have been turning ideas around in my head for a while, then one day I walked out of my shop and the first thing I saw was the old JD Gator just sitting there and then it hit me like a ton of bricks.  There is my saw mill, so I just started taking it apart, and looked at my steel pile, and had to buy a little, but just started putting ideas together and now I have a working sawmill.
Guess I was just blessed with the ability to plan something in my head and go to it.
No work on the mill tomorrow, have two of my great grand kids, then Sunday have to drive 150 miles to a funeral, then wife has a Dr. apointment Monday morning, then I go to my Audi. for a Mapping session on my Cochlear Implant on Tuesday, so looks like will be next Wednesday before I do anything else with the mill.
USN Retired
hackberry jake
What diameter are your band wheels? They look small, but maybe it's just a big mill.
jssmitch
Bandwheels are a total of 18" overall.
USN Retired
Jay Sybrandy
Hey,
Do you still have this mill ? Can you get the blade tight enough and how wide can you cut :) I want to make a bandsaw mill that can cut 4ft and use 18" tires but people said that I won't be able to get the blade tight enough :)
Making large bandsaw sawmill - 15 Years old - NZ
schmism
just order some real band wheels.  19" ground steel wheels from cooks is $700 for the set.   Its worth the investment for the most important part of the saw.
039 Stihl 010AV  NH TC33D FEL, with toys
Jay Sybrandy
Quote from: schmism on September 14, 2016, 10:43:28 PM
Im aming to spend around $1000 on the whole mill :)
ozarkgem
Get some 19" v belt pulleys from Surplus Center. I have used them for 8 yrs now and they work good. And you only buy them once.
