LT40 odd alignment issue.
Started by Dave Shepard, March 10, 2022, 08:27:53 PM
Dave Shepard
I think the 14" dimension is to the frame, or in some years, the top of the clamp.
My issue is I know what the mill can do when it's set to factory specs. I just don't know what is causing this problem. I won't settle for anything less than what I know it can do.
Remle
Quote from: Dave Shepard on October 12, 2022, 10:29:59 PM
I did check the tilt of the rollers with the LTBGAT. It does seem like something is getting out of whack under load, but no idea what.
So, this is only a SWAG, but if the roller bearings are going bad or a roller is tapered front to back , could it may be introducing the tilt under load ?
Dave Shepard
Rollers are good, not many hours on them.
Peter Drouin
I set my blade at 12", inboard and out, no bringing the outside up 1/6" The cat on my mill is heavy enough. I don't think the blade will pull the head down. Works for me. Good luck.
A&P saw Mill LLC.
License NH softwood grader.
Dave Shepard
It's always worked for me. I'm known for my impeccably square timbers. ??? ??? :(
Peter Drouin
It doesn't get any better than this.
Just trying to help, do what you want.
A&P saw Mill LLC.
Dave Shepard
Obviously there is something weird going on with my mill specifically, or I wouldn't be having this issue. I can either make square 12x12, or parallel boards, but not both.
booman
Dave, did you ever find out what your problem is/was?
2019 LT15G25WIDE, 2013 LT35HDG25, Stihl MS880 with 59" bar with Alaskan sawmill attachment.  John Deere 5045 tractor with forks, bucket and grapple.  Many chainsaws.
Dave Shepard
Haven't had a chance to work on it.
