My sawmill shed build
Started by Kwill, March 19, 2019, 08:22:22 PM
Kwill
Sawhead stays in the shop till the shed is done.i dont like things out in the rain.
Built my own log arch
built my own bandsaw sawmill
Built my own atv log arch.
Built my own FEL grapple
Waggs
This might be a stupid idea but what if you poured two concrete footers twice the length of your building ( making sure you use rebar and finish the concrete out smooth) and about a foot or so wide and deep. Install a anchor point in each corner and maybe on in the middle. Then mount some heavy duty casters on the bottom of your building. When you want to use your mill roll the build down the footer out of the way, when your done roll it back and anchor it down using a chain boomer etc......
Kwill
Got my header beam milled and set in place today.
