Day of the Demo - Pictures included
Started by tgalbraith, July 15, 2017, 06:34:56 PM
tgalbraith
Well, the day finally came, and I think the boys enjoyed it. I started out pointing out all the major components of the mill and explained how they worked. I then had a mock up carriage way, head-block and top-dog and a cookie that I made a slab and flitch cut on all four sides and re-attached with a drilled hole and a piece of arrow shaft.  I explained how we would be taking those cuts on the log, turning the flat side down and continuing until we had a cant; then completing the final cuts to get the boards we wanted. They needed two 2x10's and two
4x4 posts to make a road sign for their campground. I then explained "board feet" and showed them how my log scaling stick worked.  After getting them all into a safe viewing area, I cranked up the Oliver and cut log to their
wanted size.
   This is where I was showing them how the insert teeth are changed.
  Showing the basic cuts to reduce a log to a cant, using a pre-cut cookie
   Running the saw thru--
The final product!!   smiley_hollywood_cool smiley_clapping
A good time was had by all.
M Belsaw, 46" insert blade, Oliver 88 power  plant
You never know.  You may have inspired a new sawyer.
Sixacresand
I bet their Dads were equally impressed.  Its good that you took the time to do that, tgalbraigh.
"Sometimes you can make more hay with less equipment if you just use your head."  Tom, Forestry Forum.  Eleventh year with a LT40 Woodmizer,
slider
al glenn
tgalbraith
tgalbraith
I  guess there is still hope for this world, several of the kids have come up and thanked me at church, for giving the demonstration and providing the material for their sign at the campground. 8) 8)
sublime68charger
Very nice of you to give them Kids a demo of your mill and they now have some usable boards for there camp and when they look at those boards now they will think of how they got made as well!
tgalbraith
Here's a photo of their finished sign
cutterboy
Those boys looked like they were really paying attention during the demonstration. You did a good job, tgalbraith.
To underestimate old men and old machines is the folly of youth. Frank C.
Knute
ToddsPoint
Quote from: WDH on July 15, 2017, 07:52:49 PM
I took my first walnut log to a demonstration of sorts.  It was a thrasherman's reunion and they had a circle saw set up powered by a steam tractor and a huge belt.  I was impressed.  Got my log sawed and also got the bug.  That was 1985 and I finally took the plunge and got a CSM 6 yrs. ago.  So yes, the OP likely did inspire some young guy who now has thoughts of milling wood.  Gary
Logosol M7, Stihl 660 and 290, Kubota L3901.
I would of been paying attention too!!!!!!!!!!
SlowJoeCrow
The lil' man with suspenders already looks like a sawyer!! ;D ;D
