Sliding engine belt tightening.
Started by Kwill, February 25, 2018, 03:16:59 PM
Kwill
Here is the setup.
Problem I'm having is it doesn't lock into position. Most of them I have seen seem to cantilever over. Not sure what I'm doing wrong
Built my own log arch
built my own bandsaw sawmill
Built my own atv log arch.
Built my own FEL grapple
Kbeitz
One thing I would do is to replace that round rod with a turnbuckle. The turnbuckle would give you needed adjustment.  Your rod needs to go past center of the bolt on the left of the picture to lock.
Love machine shop work
and Wood work shop work
And now a saw mill work
Kbeitz
You need a hole for your rod somewhere where I put the new hole.
pinefeller
is this the "clutch" for the machine or just to hold tension while you tighten up the bolts?
i see what your trying to do. you need the pivot for the pull handle above the centerline of the pull angle so the pivot can cam over i wish i could draw on here! can i get a pencil button in my tool bar administrator?
for those who say "it cannot be done!" please do so quietly so as not to disturb those who are doing it.
Kwill
Quote from: Kbeitz on February 25, 2018, 07:10:32 PM
You saying it needs to be on the bottom? I do plan on getting s turnbuckle tomorrow in town
pinefeller
try clamping your pivot on top of the angle. maybe you will get a better visual when its up there. your linkage will have to be offset of the lever to it can swing by the pivot
Kwill
Ljohnsaw
Flip the blue lever arm over so the hole for the rod is on the bottom.  Now, the rod will need a 90° bend in it.  Imagine the rod having an extension going straight down from where you have it inserted into the blue arm.  With the arm up, the tension is released.  Push the arm down and when it goes past the pivot point (the bolt), it will stay down on its own.
P.S. - this whole thread should be in your main build thread.  I pity the poor soul that tries to follow your build thread in the future!
John Sawicky
SkyTrak 9038
Ford 545D FEL
Genie S45
Davis Little Monster backhoe
Case 16+4 Trencher
Kwill
Kwill
this is what I had to go by. I made it as close to the picture as I possible could
loganworks2
Move the pivot point to above the line of pull so when you pull the lever the rod to the engine plate will drop below the line of pull. This will lock the engine in the engaged position.
Kwill
Quote from: loganworks2 on February 25, 2018, 08:22:06 PM
It does
Kwill
Kbeitz
Kwill
Mine is made similar to this one. Same type lever.
loganworks2
 smiley_clapping smiley_clapping you should be good to go.
Kbeitz
If you put a strong spring on the end of the turnbuckle it will help keep the belt tight and make for easy handle snapover.
Ljohnsaw
Quote from: Kwill on February 25, 2018, 08:01:28 PM
I don't have a main build thread.
My bad.  There are SOOOO many new band mill builds going on right now, I'm getting them confused.
John Sawicky
SkyTrak 9038
Ford 545D FEL
Genie S45
Case 16+4 Trencher
Kwill
Quote from: Kbeitz on February 25, 2018, 08:40:45 PM
Where at?
Kbeitz
Kwill
Quote from: Kbeitz on February 25, 2018, 08:55:07 PM
Quote from: Kwill on February 25, 2018, 08:45:37 PMWhere at?
either end of the turnbuckle.
I think if I put a spring on the turnbuckle it will just raise the lever back up. It never does lock.
21incher
Just put a bend in the rod above the arm mounting bolt so it will lock over center before bottoming out.  an adjustment for belt stretch is a good idea also. :)
loganworks2
If it is not locking then you need to move the pivot point higher.
pinefeller
nailed it! with the turnbuckle he should be alright just stretching the belt and its infinitely adjustable.
Kwill
I'm going to pick up a actual adjustable turnbuckle tomorrow when go to town. Any certain type I should look for?
