Author Topic: Where does everyone buy their stuff?  (Read 1430 times)
Offline boonesyard
  • I've got a little sawdust in my pocket
« on: March 27, 2018, 12:01:53 PM »
Need a little help. I can research everything that I need on-line, but I figure why re-invent the wheel. I would imagine most here have a pretty good idea about the best product vs cost/value. Things I need to order:
- Anchor Seal
- Metal Detector (will be cutting a lot of yard and urban trees)
- Moisture Meter
- Blades (Wood-Mizer LT50 Diesel)
I know all of this has been covered at some point here on the forum, just thought I'd get the condensed version. Also, I've been searching for an air-drying shelter thread or two (I don't speak computer very well) and haven't really found anything that might point me in the right direction.
Thanks for any help.
LT50 wide
iDRY Standard kiln
JD 4520 w/FEL
lots of support equipment and not enough time
"I ain't here for a long time, I'm here for a good time"
Offline alan gage
Re: Where does everyone buy their stuff?
« Reply #1 on: March 27, 2018, 12:22:28 PM »
Those are all the same questions I've had while fixing up a mill and getting it ready to go. It was easy to find all of them via search and I learned a whole lot more along the way. Would hate the ruin the fun for you. :P
Alan
Timberking B-16, a few chainsaws from small to large, and a Bobcat 873 Skidloader.
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #2 on: March 27, 2018, 12:30:12 PM »
UC Coatings for Anchorseal. About $95/5 gallons shipped. I run Turbo 7s on my 51 hp LT40.
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #3 on: March 27, 2018, 12:32:53 PM »
Anchorseal, from the manufacturer, Entry Page - UC Coatings online store
Metal detector and moisture meter, figure out the brand/model you want then shop for it online.  Amazon or the many woodworking places for example.
Blades for Woodmizer I would only consider contacting Woodmizer. I buy my blades 4 boxes of 15 each, 60 at a time, and have always got free shipping and 15% off from Woodmizer.
DJ Hoover, Terrific Timbers LLC,  Mystic CT Woodmizer Million Board Foot Club member. 2019 LT70 Super Wide,  LogRite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #4 on: March 27, 2018, 12:40:21 PM »
Ditto TerrificTimbersLLC. I buy my blades from WM and use their resharp. UC Coatings is johnny on the spot shipping me anchorseal.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #5 on: March 27, 2018, 01:17:00 PM »
I got my Wagner moisture meter from Wood-Mizer.  They are not on your list but Logrites can be bought from several outlets such as WM, Stihl, and even directly from Logrite.   logrite_cool
Offline boonesyard
« Reply #6 on: March 27, 2018, 01:39:48 PM »
Thanks to all.
LT50 wide
iDRY Standard kiln
JD 4520 w/FEL
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #7 on: March 27, 2018, 01:47:20 PM »
I should have added that before you buy anything, take a cruise down the list of FF Sponsors listed in various places here on the FF.  Just going through and clicking on the banners will probably uncover stuff that you did not even know that you needed.  ;D
Offline boonesyard
« Reply #8 on: March 27, 2018, 01:53:23 PM »
And the disease begins  ::)
LT50 wide
iDRY Standard kiln
JD 4520 w/FEL
Offline SawyerTed
  • Summey Lumber Services, LLC
« Reply #9 on: March 27, 2018, 06:12:03 PM »
Don't scrimp on support tools.  In the short time I've been doing this I have a new "economy" moisture meter that will tell me the wood is wet.
On the plus side I have two Logrite can't hooks and a decent metal detector.
Woodmizer LT35HD25, Kubota MX5100, IH McCormick Farmall 140, Granberg Alaskan Chainsaw Mill, Husqvarna 372XP, Husqvarna 455 Rancher, Ram 3500 6.7 Cummins
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #10 on: March 27, 2018, 06:35:42 PM »
Everything I need to run the mill I get from WM, They keep working, I keep them working.
 The same with John Deere, Cat, and my GM truck.
A&P saw Mill LLC.
License NH softwood grader.
Offline JB Griffin
« Reply #11 on: March 27, 2018, 07:52:42 PM »
For blades I have not found any better blades than Kasco, great prices and even better blades. Member Cutting Edge can hook you up, and even help with which blade will suit your needs. And also provides sharpening services for most any blades.
2000 LT40hyd remote 33hp Kubota, 160 Prentice, Frick 2 saw gang edger, Wright W-37 ABG, Suffolk dual tooth setter, Cat claw single tooth setter,'96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c, M681 Memo.
Over 2.5 million bdft sawn with a Baker Dominator and counting.
Offline Brad_bb
« Reply #12 on: March 27, 2018, 09:01:37 PM »
I use a Garrett super scanner Handheld wand. I think  The current model is  V? I suggest going straight to the manufacture as I believe there are some fake counterfeits from Asia out there.I just bought a Wagner model 210 moisture meter, but havenít had any use on it to be able to rate it.
Offline starmac
« Reply #13 on: March 27, 2018, 09:16:08 PM »
Kasco is also a band supplier that a lot of folks use, I think member cutting edge is the guy to deal with on them, or at least one of the guys.
Disclaimer, I have not used any of theirs, but he does appear to know his stuff on them.
Offline boonesyard
« Reply #14 on: March 27, 2018, 09:55:37 PM »
- Ordered my anchor seal today
- will pick up my cant hooks when I pick the mill up in 2 weeks
- may pick up the Wagner moisture meter at the same time
- will figure out the metal detector as we go
- I've ordered two boxes of Turbo 7s with the saw to try
Can't wait to get started
LT50 wide
iDRY Standard kiln
JD 4520 w/FEL
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #15 on: March 27, 2018, 09:57:49 PM »
If I can't find it at the junkyard then it's E-bay for me.
Love machine shop work
and Wood work shop work
And now a saw mill work
« Reply #16 on: March 27, 2018, 10:21:53 PM »
   Congrats. As to the blades I think WM offered a sample pack a while back. You might want to try them. Blade type is generally tied to the type wood you will be cutting for best performance.
Kid Stuff? Nah...
Started by Jeff on The Outdoor Board
Last post April 04, 2002, 05:21:18 PM
by Don P
Stuff Happens...Again
Started by Magicman on Sawmills and Milling
Last post June 27, 2013, 07:13:50 AM
by Magicman
Not getting Much Done Because of Stuff Like This
Started by Percy on General Board
Last post October 26, 2019, 09:28:23 PM
by luap
New stuff
Started by sandhills on FOOD! FOOD! FOOD!
Last post August 13, 2014, 12:08:08 AM
by sandhills
