Author Topic: Bluecreeper Testament  (Read 1892 times)
Offline Chuck White
  • Sawing Mobile since 2005
« on: April 27, 2018, 01:32:22 PM »
My usual use for Blue Creeper is applying a drop on each end of my tooth setters readout dial indicator rod every once in a while!
A couple of days ago, I had the blade guide motor off of my sawmill, checking for stretch in the chain!
While it was off I noticed that not only was the chain stretched, but the sprocket on the end of the motor was worn!
The sprocket and the roll-pin were severely rusted in place, I tried drifting the roll-pin out, but it just didn't want to move, so I applied a couple of drops of Bluecreeper at each end of the roll-pin and both sides of the little sprocket and repeated with the Bluecreeper again in the evening!
This morning I went out and the roll-pin just drifted out just like it was supposed to!
Then I went to my tool box and got my little battery clamp puller and clamped it onto the sprocket and against the shaft and the sprocket came off so easily that I could hardly believe it!
As long as Bluecreeper is available, I'll always have some on hand!  8)
~Chuck~
Retired USAF 1989, Retired School Bus Driver 2012, now semi-retired Mobile Sawyer
1995 Wood-Mizer LT40HDG25 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline Tam-i-am
  • Board Moderator
  • Gender: Female
    • Logrite
Re: Bluecreeper Testament
« Reply #1 on: April 27, 2018, 02:25:24 PM »
Thanks Chuck!
Glad you found Bluecreeper to be helpful!
Offline Chuck White
« Reply #2 on: April 27, 2018, 02:51:35 PM »
A friend of mine once asked me "What's in that, anyway"!
I replied BlueCreeper!   ;D
~Chuck~
Offline Chuck White
« Reply #3 on: August 24, 2018, 06:56:12 PM »
Used some again today!
I changed the "feed" chain and sprocket and shaft (upgrade), had a little trouble getting the power feed drive pulley off, added a couple drops to the shaft on both sides of the pulley and went to lunch!
Couple minutes messing with it when I got back out there and had it apart!
Still have about 3/4 of the bottle left!
Great stuff!  :)
~Chuck~
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #4 on: August 25, 2018, 09:37:37 AM »
Yup, it is just a natural reaction to reach for the Bluecreeper.  I did twice this week.  ;D
Offline tawilson
« Reply #5 on: August 25, 2018, 09:43:34 AM »
I picked up a bottle in Boonville. Haven't had a chance to use it or the pickaroon I bought at the same time. I'll be back at the mill and the shop next week after my house painting project so they'll be put to use then.
2017 LT40HDG35 WIDE
BMS250 and BMT250 sharpener/setter
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #6 on: April 14, 2020, 03:48:55 PM »
  I was removing and sharpening mower blades today, had my mower lifted with my ATV winch and using a 1/2" electric impact wrench to remove the blade nuts. The nut on the center blade was frozen and just would not move. I had been working on my mill and had my toolbox in the ATV basket and I remembered I had a bottle of Blue Creeper in the top of the box. I got it out, and ran the needle applicator around the nut then the washer and let it sit a minute or two. I put the socket back on the nut and ran it forward and back a couple times and the nut broke free and spun right off. I thought I was either going to have to take a torch to it or saw it off and replace the shaft on the spindle. A shot of Blue Creeper turned out to be a lot easier, faster and cheaper.
Offline barbender
« Reply #7 on: April 15, 2020, 12:43:26 AM »
I just ordered a Logrite Peavey and hookeroon, and was disgusted with myself when I realized I forgot to order some Bluecreeper to try out.
Offline thecfarm
« Reply #8 on: April 15, 2020, 06:31:33 AM »
That's too bad.  :(
As they say, they can sneak in a bottle and that saves on shipping. I need to order a bottle too. Maybe they can sneak in a cant dog.  :D
Offline Bibbyman
  • Pro-Sawyer Mary and Bibbyman
    • Warden Sawmill
« Reply #9 on: June 27, 2020, 10:04:14 PM »
Mary and I have seriously retired from sawing.  But I still use BlueCreeper when I'm restoring old guns.
Sawing since '94
Offline thecfarm
« Reply #10 on: June 28, 2020, 05:41:13 AM »
Nice to hear from you!!!
Glad you are enjoying your guns.
Another Bluecreeper Testament
Started by Weekend_Sawyer on Bluecreeper
Last post February 06, 2018, 03:32:10 PM
by Tam-i-am
Testament to Woodmizer!
Started by ChadH on Sawmills and Milling
Last post November 12, 2016, 05:40:01 PM
by red
Just one more use of BlueCreeper
Started by Brad_bb on Bluecreeper
Last post September 21, 2011, 02:51:20 AM
by Brad_bb
BlueCreeper SMO
Started by gspren on Bluecreeper
Last post December 12, 2019, 11:03:34 AM
by Tam-i-am
