Tally-I/O
Author Topic: pecan thickness  (Read 697 times)
Offline E-Tex
  • Rather be Saw'n or Fish'n
    • www.L2Sawmill.com
pecan thickness
« on: May 01, 2018, 09:36:06 PM »
customer wants 7/8  - 15/16" final finished size in Pecan lumber.
Is 1 & 1/8 or 3/16 plenty for rough sawn thickness?
LT-50 Wide, Mahindra 6065
L2 Sawmill LLC
Offline WDH
  • Forester
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: pecan thickness
« Reply #1 on: May 02, 2018, 07:02:42 AM »
I would go at least 1 3/16" thick.  Pecan likes to cup, and it likes to dry in waves where it kinks at the knots.  I generally cut it 5/4 thick, 1 3/8" rough, so that I can get a full 1" thick finished.
Offline GeneWengert-WoodDoc
Re: pecan thickness
« Reply #2 on: May 02, 2018, 07:21:27 AM »
When you cut 1.125, this is the average and there is variation.  So the thinnest piece or spot is likely 1.035.  Then there is a maximum of 8% shrinkage, but most are less. It would be rare that the thinnest piece is also the maximum shrinkage, so we will use 7% shrinkage in drying to give us the thinnest piece of 0.91.  Now, add for cup (?) and planer allowance (0.03).  Recalling that all pieces are thicker than the minimum, we do not need a big allowance for cup usually, especially with good drying.  So, final planed size is about 0.87.  Do your own calculations.
Offline firefighter ontheside
  • I like trees.
Re: pecan thickness
« Reply #3 on: May 02, 2018, 08:06:19 AM »
My pecan dried exactly as Danny described.  It was in waves about every 16.  Luckily Andy sawed it thick enough that when I skip planed it, it was still 1.  Final planing by the guy who bought it was gonna be more like 7/8 when said and done.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
Offline E-Tex
    • www.L2Sawmill.com
Re: pecan thickness
« Reply #4 on: May 02, 2018, 08:08:50 PM »
i'll share this info with the customer and suggest..... 1 3/8"
thanks all!
L2 Sawmill LLC
Which Thickness?
Started by Horselog on Sawmills and Milling
Last post April 01, 2016, 10:01:24 PM
by 280 rem
Thickness for 4/4 lumber?
Started by WoodChucker on Sawmills and Milling
Last post September 24, 2004, 06:51:36 AM
by Brian_Bailey
Board thickness
Started by Clover on Sawmills and Milling
Last post March 19, 2017, 04:43:11 PM
by Warren
Keep gaining thickness
Started by True North on Sawmills and Milling
Last post June 08, 2009, 05:24:41 AM
by Meadows Miller
