What's a fair deal (and advice) for a small guy needing logs?
Started by cbay, May 14, 2018, 09:51:38 PM
cbay
Several questions,   i'm a beekeeper and trying to grow my operation.   Need pine badly for equipment.   No pine around my area.   Got an Lt15 and want to save money milling my own boards.
If i can find a source for pine saw logs what is a fair price?    Found one about an hour away and he wants .50 / bf.   Don't think i want to swing that.   Another about 2 hours away quoted my .40 / bf.   That sounds a little better.   Was hoping to find in the 30ish range but it doesn't look like that's going to happen.
Our trailer is a small 5x10 dump so it wouldnt be worth the expense to go all that way for such a small load, so my neighbor offered to haul a bigger load with his 16 ft trailer and truck.    Any idea if a 1000 bf would be too much for a 1/2 ton truck?
A real shame i can't use lumber from our 80 acres, but the oak, hickory and walnut is too heavy for bee hives.   Got sycamore  as well but was reading that they walk around too much by the time they dry.
Any suggestions around this whole topic would be greatly appreciated, and thank you in advance.
Regards,
Chris
mike_belben
Saw some of your oak, sell the lumber, buy some finished pine lumber, tend bees, profit.
Praise The Lord
Southside
Mike has very good advice there. 1000 BF of SYP logs will weigh between 10,000 and 12,000 lbs, not including the trailer. Not something I would want to do with a half ton pickup that I owned.
That can't be right is it? 10 to 12 lbs a bf?  Oak is only 6
Southside
You are right Jeff - 5,000 to 6,000 lbs, per 1000 bft, it's that new math.
Pclem
I thought there was 2.2-2.5 cords in 1000 bf (of logs). That would be pushing 10-12k lbs wouldn't it? ( for oak ). Don't know about syp weight, but a little over 2 cords of logs? That's a big load
Dyna SC16. powersplit. supersplitter. firewood kilns.bobcat T190. ford 4000 with forwarding trailer. a bunch of saws, and a question on my sanity for walking away from a steady paycheck
cbay
Thanks,
Mike, we really don't want to lose oaks off the property if we can help it.    They are precious to us just to have them.   Otherwise that would make a lot of sense.   Maybe some hickory in the future though.
We will be sure and give thought on the weight and be safe about it.
mike_belben
I had to go look at my slip from brown foreman.. I sold 1300 bf doyle of WO stave logs and weighed on their scale before and after at 23,500 of logs.  So 18lbs per bf.  Ive heard all oaks avg at 14-16 bf doyle.
Praise The Lord
mike_belben
I do think itll be 10-12k and if its a 5 lug car trailers theres just not enough brakes, tire or axle to be certain you wont blow or bend something.  On a 3 axle id do it, if they work triaxles have great brakes.  A half ton truck will just skid in a panic stop with that much behind it.  Btdt.
If its close, flat and all backroads maybe.  If its far, hilly and interstate definitely bad.  If DOT sees 1000bf behind a half ton you are getting the portable scales and a roadside colonoscopy.  Maybe an impound or criminal charge.  Done that too.
Praise The Lord
TKehl
Why not use Cedar for bee equipment?
Light, rot resistant, and abundant in SW MO.
luvmexfood
I have a half ton pickup. Use a flatbed trailer. No gooseneck. Just travel back roads except maybe a mile on fourlane to the log yard. Have hauled about 450 bd feet of poplar and it's about all I want back there. It's only about six miles and I crawl along.
luvmexfood
My post may have been confusing. That is the largest load of one species. Could you possibly get someone to furnish the logs and saw on the shares.
cbay
Thanks guys,  wow i was underestimating the weight and glad i posted here about this.   Thank you all for the feedback.
May have to reconsider this and look for better ideas.
TKehl,
cedar is around here and have considered it even though it's more expensive.   Would definitely last longer.
luvmexfood,
not sure how that would work, maybe i can look into that...
Bottom line is i would like to have some good usable lumber here as inexpensive as possible.   Going to check with the local amish sawmill and see if he gets any poplar.   Talked to him once but only asked about pine - which he doesn't see.
He wants some pollination for his vegetable business so maybe something could come of it.
Quote from: Jeff on May 15, 2018, 08:22:07 AM
I was thinking you were talking lumber weight.
5 tons per MBF is about right for SYP logs depending on the size of the logs.  Really big logs will be more like 4 tons per MBF.
BargeMonkey
 I'm sending redpine to Deposit NY right now and its 5ton per mbdft conversion.
 .50 cents would buy you gorgeous pine up here, its .30 cents delivered for redpine, white pine, hemlock. I've got a mountain of 8-10-12ft stuff I've been selling cheap on this job, the overseas market is all 13-6 19-6 right now.
YellowHammer
Generally, as a rule of thumb when I'm hauling with my DOT registered and regulated diesel pickup and double axle, single wheel gooseneck, I try to cut the log loaders off at 1,000 bdft of hardwood, or 1,100 bdft of pine to get me to just under CDL weight of 26,000 lbs on the truckers scales.  Sometimes I'm a thousand lbs or so light, but better that than to come in heavy.  I'd never want to do that load in a half ton pickup.
Sycamore flatsawn moves a lot, but for building bee boxes, I'd give it a try.  Quartersawing it to make it more stable would certainly work.
Most properties have more than oak and hickory, what other species do you have?  I'd also seriously consider selective harvest on distressed trees or trimming back fencelines and property boundaries to scavenge usable timber.
How many bdft does a hive take?  Seems like it wouldn't take too many logs to make a lot of hives.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
mike_belben
I think.pine is $200/thou here, ive not cut a one.
Red maple is the pine of my life.  And i sure do try to smother it in the cradle.
Praise The Lord
cbay
YellowHammer,
it takes around 6 bf just for a hive body.   Then lids and bottom boards, inner covers...    So to make several hundred completed boxes takes up quite a bit of lumber.
Not real experienced with a tree or two out there, but think one that we have a few of is hackberry.   I was thinking they were a cottonwood but after looking online they look more like hackberry.     Don't know how they would work out.
Bargemonkey,
I would absolutely flip out to have pine delivered for anywhere in the .30 range.   Would be swimming in bee equipment come this winter.  Lol
It's early yet, but did find out that not allowing wood enough time to dry makes for some wonky hives. lol     So trying to get ahead of things for this winter.
TKehl
Hackberry would be fine if quarter sawn.  It's related to elm and likes to twist if flat sawn.  Nice and light when dry, but rots quick.  I'd only use it someplace where it can shed water quickly, even then it's so so.
Quote from: cbay on May 15, 2018, 09:40:02 PMTKehl,  cedar is around here and have considered it even though it's more expensive.   Would definitely last longer.
I see milled cedar in your neck of the woods selling at $.60/bf on C-list.
If that's too much, most farmers in the area will let you have all the cedar you can cut for free.  Sometimes I get paid to cut it...
Quote from: cbay on May 17, 2018, 01:34:38 PMIt's early yet, but did find out that not allowing wood enough time to dry makes for some wonky hives.      So trying to get ahead of things for this winter.
Cedar.  One of the quickest drying and most forgiving woods out there.
Just saying...  ;)  (No I'm not getting paid by the Cedar checkoff, but should be.   :D)
cbay
Quote from: TKehl on May 17, 2018, 02:03:30 PM
Thanks TKehl,
Ill keep looking.   Not seeing any yet that will get me 10" boards milled for a decent price.   Did chat with a guy on FB a month ago
that had a load of cedar and probably could have grabbed that for .60/bf.
If it continues to be this difficult to get the pine then cedar is going to be the route i take.
Amazing how a 100 or so miles can change things so much.
YellowHammer
I had heard that bees don't like the aroma of cedar, at least that's what a commercial beekeeper buddy told me a few years back.
Hackeberry is as TKehl describes.
Sounds like you are planning quite an expansion.  Sounds exciting.
YellowHammerisms:
Just Right
Ever thought of renting a U-haul for the day and go get some pine?
If you are enjoying what you are doing,  is it still work?
mike_belben
Just dont tell them what youre up to.  Last time i called uhaul their policy was no trailer rental unless its behind a big gutless gas hog box truck.  Dont know if it was franchise or national policy.
Praise The Lord
TKehl
Quote from: cbay on May 17, 2018, 10:00:00 PMNot seeing any yet that will get me 10" boards milled for a decent price.
Dumb question maybe, but do you need 10" boards?  These guys don't use single boards for their deep supers:
https://www.ozarkcedarhives.com/hive-bodies-and-supers
I would think a rough (tablesaw) tongue and groove would be nice as opposed to just glue and biscuits.
cbay
I run all deep hives (9 5/8"),  i say 10" to give me enough to square things up.
Thanks everyone,  bunch of good guys on here.   Lots to learn.  Hopefully i can contribute more as time goes by.
