Author Topic: Kd250 kiln schedual  (Read 754 times)
Offline Woodslabs
  • Check out my wood mill in Toronto
    • Live edge wood slabs Toronto
Kd250 kiln schedual
« on: June 07, 2018, 11:55:26 PM »
Hi all,
I have been running a Kd250 for 2 or so years now. I find that the kiln shedual provided in the manual doesn't really force the compressor on very often. Like for example I'm running wood type 4 at 50% moisture. Manual says 95/89 temps. When I do that the wet bulb will stay 90.5 or so and won't turn on the compressor as it needs to be 2 degrees higher.  I usually set the wet bulb 1 degree lower than what the manual says and it works great. Anyone have the same issue?
I dry mixed hardwoods at 2 and 1/4 thick.
Offline GeneWengert-WoodDoc
Re: Kd250 kiln schedual
« Reply #1 on: June 08, 2018, 06:51:35 AM »
Take the wick off the WB and dry it off.  This makes it a DB, and it should read the same as you regular DB.
In order for a WB to work well, it needs pretty good air flow in order to evaporate the water and cool it.  The wick also needs to be very wet.
Offline K-Guy
    • http://www.nyle.com/
« Reply #2 on: June 08, 2018, 09:10:31 AM »
Our kiln schedules are conservative because it makes it easy for new users to get a good result. Also because our schedules are for all of North America and wood can dry a little differently from region to region. :)
Nyle Kiln Sales & Service
"He has all the virtues I dislike and none of
 the vices I admire." -Winston Churchill
Access output from Woodmizer KD250 Kiln from web
Started by aarontaddiken on Drying and Processing
Last post April 06, 2019, 06:57:17 PM
by btulloh
Getting to 8% KD250
Started by Woodslabs on Drying and Processing
Last post September 09, 2018, 07:17:31 PM
by WDH
KD250 fan switch issues
Started by Southside on Drying and Processing
Last post October 13, 2018, 09:48:13 PM
by scsmith42
Help with the l200/kd250 powered vent kit
Started by Hot Shot Rob on Drying and Processing
Last post June 27, 2018, 08:32:09 AM
by K-Guy
