Author Topic: 74 f600 wonít start  (Read 1781 times)
Offline bigred1951
  • logging and sawmilling
74 f600 wonít start
« on: June 15, 2018, 09:53:44 PM »
My 74 ford f600 dump truck is getting bitter in its old age. Itís always run great and never failed to start until the other day. I drove it an hour away to my in laws house. I stopped about 10 miles before I got there and got something to drink. Come back out it started fine then went on to their house and parked it. A couple hours later I went to move it and it wouldnít start just kept cranking. I thought might have been fuel pump went out so poured a little gas down the carb and still wouldnít hit. Well a couple days later went back and it fired right up like nothing happened. Then today I drove it around 30 miles round trip to the dump and back. Started fine this morning no problem. It sit for a few hours when I went to get in to bring it home again it just cranked and cranked and wouldnít hit. Iím betting tomorrow I can go and itíll fire up first crank. I looked for a icm or brainbox we call it because Iíve heard they are bad for going out but didnít see one. Itís a 330 v8. Any ideas whatís causing this.
Online WV Sawmiller
    • Green's Sawmill Services
Re: 74 f600 wonít start
« Reply #1 on: June 15, 2018, 10:21:24 PM »
   No mechanic but could a needle valve or something be sticking in the carb? Might tap it with a wrench or something the next time it happens. If it is a good cleaning might fix the problem. Good luck.
Offline mike_belben
  • Pulp Friction
« Reply #2 on: June 15, 2018, 10:42:36 PM »
Put a timing light on it.. Ill bet theres no spark during the no start period, and that its that little finned aluminum ignition box thingy on those old fords.  Had a bronco that did this often.
Revelation 3:20
Offline bigred1951
« Reply #3 on: June 15, 2018, 11:09:22 PM »
The little aluminum looking finned thingy what I was referring to when I said the icm which is ignition control module. Or as a Iíve always heard it called the brainbox. I looked for one on it but couldnít find it no where.
Online caveman
  • In the land of the blind the one eyed man is king
« Reply #4 on: June 16, 2018, 12:41:54 AM »
I think '74 was a few years before Ford started using electronic ignition on their trucks.  You probably have points and a condenser in the distributor.  If you are getting no spark when it will not start, that may be a good place to start looking for the source of your problem.  Another possible culprit may be the ignition coil.
Don't overlook the simple stuff.  It is a good idea to ensure all of your grounds are good - does not cost anything to check/clean them.  Good luck with it.
Offline jcbrotz
    • Brotzmans Woodworks
« Reply #5 on: June 16, 2018, 04:35:17 AM »
Remove the coil and turn it upside down and back if you feel liquid move in it its bad. Unless its been retrofitted it would not have electronic ignition.
2004 woodmizer lt40hd 33hp kubota, Cat 262B skidsteer and way to many tractors to list. www.Brotzmanswoodworks.com and www.Brotzmanscenturyfarm.com
Offline LAZERDAN
« Reply #6 on: June 16, 2018, 07:56:58 AM »
Yep,,,,,,,,,,, check the coil wire also                                                    Lazerdan
Online PineNut
« Reply #7 on: June 16, 2018, 08:42:52 AM »
I had a similar problem on an old GM school bus. While going down the road, it would decide to quit. I finally tracked it down to a small crack in the rotor in the distributor. I could not see the crack but it must have been there. Whenever it got warm, it would change enough to ground out the spark. Replacing the rotor fixed the problem.
Offline scsmith42
    • Whispering Pines Farm
« Reply #8 on: June 16, 2018, 09:14:03 AM »
I would check the resistor and coil first.  What you describe is a classic case of either one going bad.
To check the resistor, first locate it and then keep a small jumper wire with you.  The next time that the truck wonít start simply bypass the resistor with the jumper wire.  If it starts, youíve found your problem.  Donít leave the resistor bypassed long term or your points will burn up.
Tom's 3638D Baker band mill
Offline mike_belben
  • Pulp Friction
« Reply #9 on: June 16, 2018, 09:50:34 AM »
Check the distributor rotor for slop in the bushings.  Once the shaft starts drifting around in there you cant maintain breaker gap and they get arced up and eaten away quick.  Id pull your condensor and just go match up another theyre only a few bucks and not easy to test. The coil can be tested with a meter pretty easy just google it. Replace breaker plate and reset gap if youve never done it.
 And if youre gonna keep that old girl, buying a few spare parts is a good idea, its going extinct. The 4cyl ford in my bobcat has an obsolete distributor.  I finally had to buy an entire pertronix setup @ $300 ish to have spark.
Revelation 3:20
Offline woodmaker
« Reply #10 on: June 17, 2018, 10:10:04 PM »
I don't know about the larger fords in 1974,but my dad had an f 100 that had something called t.f.i. for an ignition ( thin film or thick film,I don't remember,and my books aren't here).What i remember is you had to change both components if one failed; we didn't,and it failed again in a very short time.
franklin q80,builtrite 40,husky 372,sachs dolmar 123, dozers,excavators,loaders,tri-axle dump trucks ,autocar tractor with dump,flatbed and detachable trailers, and 8  f350 diesels
Offline bigred1951
« Reply #11 on: June 18, 2018, 09:18:03 AM »
Iím gonna go later today to see if itíll start again and bring it home. Iím sure itíll fire right up. My father in law seems to think that itís vapor locking. You shut it off it starts right back. If it sits for a couple hours it wonít.
Offline dgdrls
  • Learning the Art of Milling Logs
« Reply #12 on: June 20, 2018, 09:32:51 PM »
you get that ford home yet?
D
Offline jwilly3879
« Reply #13 on: June 21, 2018, 08:01:36 AM »
It was an intermittent ignition switch on my old Ford, it would engage the starter but not put any juice to the coil (sometimes.) I found this by putting a jumper from the battery to the coil and it would fire right up.
Offline Weekend_Sawyer
  • Jack of all trades, master of fun
« Reply #14 on: June 21, 2018, 01:19:30 PM »
On points ignition a failing condenser will heat up and quit.
I would start by doing a basic tune up, plugs, wires, points and condenser and distributor cap.
Imagine, Me a Tree Farmer.
Jon, Appalachian American Wannabe. ... and it looks like my dream will come true!
Offline bigred1951
« Reply #15 on: June 21, 2018, 01:55:36 PM »
Yea itís Home. Like I thought it started right up and drove the 50 miles home just fine. When I got home and shut it off it fired right back up. I didnít go try it after it set for a couple hours though.
F600 Jotul Parts
Started by newoodguy78 on Firewood and Wood Heating
Last post September 07, 2016, 11:04:20 PM
by newoodguy78
Air Leak Jotul F600
Started by mitchstockdale on Firewood and Wood Heating
Last post February 13, 2019, 05:16:54 PM
by Pulphook
Where can I find rear axle parts for a 1964 F600?
Started by scsmith42 on Wanted
Last post August 24, 2013, 05:39:55 PM
by scsmith42
moved
MOVED: Where can I find rear axle parts for a 1964 F600?
Started by chet on General Board
Last post August 08, 2013, 10:33:02 PM
by chet
