Author Topic: Need Help Identifying Tree  (Read 826 times)
Offline ewhite2316
« on: June 23, 2018, 02:27:49 PM »
I need help identifying a tall tree in the woods in my backyard in Indiana.  The pods have a citrus smell and are falling now.  The tree is too tall with no low branches to take a picture of a leave.  Can anyone help?
Offline Southside
    • White Oak Meadows
Re: Need Help Identifying Tree
« Reply #1 on: June 23, 2018, 02:49:22 PM »
Can you get a picture of the bark?
Offline DelawhereJoe
  • Trapped in Delawhere
« Reply #2 on: June 23, 2018, 03:03:16 PM »
Does it have large heart shaped leaves or compound leaves ?
Offline WDH
  • Forester
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #3 on: June 23, 2018, 08:25:26 PM »
I believe that they are immature hickory nuts that have aborted.  This is a very common occurrence to see these small, undeveloped hickory nuts in the heat of the summer.  A bruised, green, hickory nut husk has a very strong, distinctive odor.
Offline ewhite2316
« Reply #4 on: June 24, 2018, 10:38:46 AM »
This is the trunk of the tree and a BAD photo from the ground as there are no low branches.  I also have a large black walnut 30 to 40 feet away and the pods may have blown from it ???
Offline WDH
  • Forester
« Reply #5 on: June 25, 2018, 07:54:09 AM »
False pignut hickory, also called red hickory, Carya ovalis.
Virginia Tech Dendrology Fact Sheet
Help in identifying this tree
Started by Jarrett on Tree, Plant and Wood I.D.
Last post January 31, 2020, 10:32:24 AM
by WDH
need help in identifying this tree
Started by alsayyed on Tree, Plant and Wood I.D.
Last post January 03, 2015, 04:14:42 PM
by wdmn
help identifying tree
Started by dirtmover1250 on Tree, Plant and Wood I.D.
Last post May 24, 2015, 06:50:18 PM
by wdmn
Need help identifying a tree
Started by joshcathey on Tree, Plant and Wood I.D.
Last post April 26, 2016, 01:33:13 PM
by mesquite buckeye
