Can you cut larger logs by spinning them 180 degrees and making two cuts or is lining back up non practical.?
I’ve also seen an old hillbilly setup where instead of running belts and sheaves, they ran the tire against the blade sheave, chained the car down good, and put it in drive.
Started by loggah on Sawmills and Milling
Started by nk14zp on Sawmills and Milling
Started by Farmer_17 on Sawmills and Milling
Started by kmdfarm on Wanted
