Tally-I/O
Author Topic: nyle L200  (Read 744 times)
Offline pineywoods
nyle L200
« on: July 18, 2018, 09:22:26 PM »
I just acquired this unit from an estate. Been in storage for a long time, no manuals, appears to have never been installed. Only 1 probe, a temp sensor..I already have a perfectly good solar kiln, open to suggestions for how to make use of the nyle. It was just too good a deal to pass up
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
Re: nyle L200
« Reply #1 on: July 18, 2018, 10:41:36 PM »
Iíd hook it up and see if the compressor, seals and Fren charge are still good.  It appears to have the basic timer controller, where the compressor duty cycle is set in minutes of the hour, and the temperature probe doesnít control much except displaying and controlling the temperature in the kiln, and forcing a minimum temperature, mine is factory set at 80į, that the kiln must reach before the compressor can kick in.
If itís running, you could sell it pretty easy.  Or you could build a really big food dehydrator.   :D
HobbyHardwoodAlabama.com
Offline GeneWengert-WoodDoc
Re: nyle L200
« Reply #2 on: July 19, 2018, 02:04:13 AM »
A refrigeration technician could best evaluate this.  Running it with low Freon or other issues can damage the unit.  Although the timer system works, it is advisable to get an RH and temperature probe that can be used in the kiln.  Consider Delmhorst HT 3000 or similar.
Offline K-Guy
    • http://www.nyle.com/
Re: nyle L200
« Reply #3 on: July 19, 2018, 02:24:12 PM »
Hi Pineywoods
Stan from Nyle here. I can get you a manual by email. You can reach me at 800-777-6953 ext 212 and at service@nyle.com
Nyle Kiln Sales & Service
"He has all the virtues I dislike and none of
 the vices I admire." -Winston Churchill
Re: nyle L200
« Reply #4 on: July 19, 2018, 05:15:59 PM »
The units have a low pressure and a high pressure Freon switch.  If the charge is too low, it wonít run.  If the pressure is too high, i. e. operating too hot, it wonít run. There is about a dozen wires that need to be connected from the controller to the unit, they are labeled with numbers, and itís plug and play.  Of course, the safeties can be jumped, but they are there for a reason.
The Freon charge is finicky in these things, and if it has leaked out, itís difficult to recharge by pressure gauges, so weighing in the charge is the best thing.  The refridegerant is available from Autozone or Oreilleyís.  These are very nice units and easy to work on.
Nyle L200
Started by WillWarner on For Sale
Last post November 03, 2016, 02:39:40 PM
by Kcwoodbutcher
Nyle L200
Started by ahlkey on Drying and Processing
Last post December 24, 2009, 06:39:50 PM
by DR_Buck
Nyle L200 Value
Started by WillWarner on Drying and Processing
Last post May 14, 2015, 07:20:36 AM
by GeneWengert-WoodDoc
Nyle L200
Started by Brad_S. on Wanted
Last post November 25, 2007, 11:52:28 AM
by Brad_S.
