Dynamic Green Products Inc.
Author Topic: Daily carnage thread  (Read 24471 times)
Offline mike_belben
  • Pulp Friction
Re: Daily carnage thread
« Reply #120 on: February 14, 2019, 07:06:54 AM »
Good eye, its a quickie Q750.
I suspect theyre made of some stamped slightly alloyed plate that the 250X did not like, as it welded very blobby and sputtery like when patching a dump body.  I made my hitch right after on the same settings with hot roll and it melted in beautiful.
Revelation 3:20
Offline starmac
« Reply #121 on: February 14, 2019, 12:12:44 PM »
Mike, I started running into some new metal a few years ago that would have sand or something in places in it, it was juust plain old mild steel and would even cause a sputter rafter grinding clean and using a wire welder with gas.
Offline mike_belben
  • Pulp Friction
« Reply #122 on: February 14, 2019, 12:24:41 PM »
Yeah maybe youre onto something.  i guess it could just be some chineseum pot metal garbage in there.  I have no doubt that it was prepped and clean,  that the welder is good and that i can weld.  But that was the nicest i could get out of it and there was a lot of black sootyness to be brushed off between passes, more than normal.
Revelation 3:20
Offline starmac
« Reply #123 on: February 14, 2019, 12:51:05 PM »
It is just my theory, but looking at your pictures, I am prone to belive something like that was going on.
I have noticed factory welds on a lot of stuff built in the last 15 or so years look similar, and some of it is machine welds, taking the human equation out of it.
Offline starmac
« Reply #124 on: February 14, 2019, 01:02:29 PM »
I forgot to ask, is your spindle on your rig salvageable?
Offline mike_belben
  • Pulp Friction
« Reply #125 on: February 14, 2019, 02:50:31 PM »
Well, nearly 30yrs of welding hasnt done my eyesight any favors, so i do swerve around like a drunk when i lose track of my lane, which is often on flat plane work.
The spindle threads wiped out.  I got another from the junkyard off a 2001 model 4700 with the double lock pins. I mushroomed a few punches before drilling the staked flush head pin. then messed up a ball peen hammer beating on the kingpin.  Finally had to throw in the towel and pay the $200 [vs $100] to have them torch the beam off.  I wasted like 4 trips over a week on that.  Then my buddies 30T press wouldnt budge the pin so i just cooked the whole pile into slag with oxy propane to get the knuckle cleaned off.
Need money to come in before i can order a kingpin kit.  Then more money for caliper and brake hose.  Then more for a tire.  Such is life.
If youre gonna lose a wheel bearing, PARK AND HAVE IT TOWED BEFORE THE HUB FLIES OFF!  Youll save a fortune.
Revelation 3:20
Offline Don P
    • Calculator Index
« Reply #126 on: February 14, 2019, 06:31:01 PM »
Well, the Ranger is getting a new long block. The oil pan was full of metal shavings and the top end was knocking. Got the shavings cleaned out but knew it was a matter of a mile or two. This time there was a cam bearing in the pan, 3 collapsed lifters, a shattered lifter keeper and another cam bearing squirting out of its journal, cam sensor gear worn razor sharp, the cam looks, umm, interesting. Somehow I suspect they aren't going to core this one. Nothing flew outta the block but it's kind of impressive inside. If I'm lucky I'll dig outta this hole about June :D
Offline luvmexfood
« Reply #127 on: February 15, 2019, 01:54:42 AM »
Don. The way it's going our way I don't know if the mud will be out of the hole by then. According to the channel 5 weather your getting it as bad as we are. Maybe worse. Wasn't going to go back out on the road doing any work for the company I do some work for. Stay here and log some. Mud and bank account tells me I will be in Pittsburgh for next two weeks.
Offline snowstorm
« Reply #128 on: February 16, 2019, 04:52:11 PM »
for the last couple weeks we are breaking plow trucks faster than i can repair them. the volvo has had far less problems. only a brake hose and abs valve along with the bearing on the spinner. ih several hoses. it wasnt that the hose broke the fitting rust to the point of leaking. broke a center bolt in the rear. thats mondays job. f550 broke a hose just as the county cop went by. sprayed his car with oil. he thought it was funny. today front axle u joint and it destroyed the short axle shaft. dealer didnt have the parts but they are in the warehouse in ct. be here Tuesday. i think i have had 4 days off since nov 1 either plow sand or repair. and i did see a mailbox get completely run down by.... the mail man.
Offline mike_belben
  • Pulp Friction
« Reply #129 on: February 16, 2019, 07:52:34 PM »
Oof, thats a handful.
Revelation 3:20
Offline AZ_builder
« Reply #130 on: February 16, 2019, 08:00:02 PM »
Knock on wood, my carnage is minimal compared to what Ive read here. I need to hang out with you crazy (ADMIN LANGUAGE EDIT)
Offline Randy88
« Reply #131 on: February 17, 2019, 09:15:43 AM »
Nice to read I'm not the only one who has stuff to fix all the time, you'd think after almost four decades of fixing, you'd eventually run out of things in need of repair or maintenance.
Mike a question about your torque flex axles on your trailer that broke, was it the axle itself that broke or the mounting plate that bolts the axle to the trailer?       For what its worth, when you win the lottery, they make trailers now that are hot dipped galvanized and won't rust ever, best deal out there for the money, I had my service body on my service truck dipped when it was new, that was almost 15 years ago now and it looks like the day it was first done, no rust what so ever, the truck however might need to be replaced soon due its cab and frame rust, but the service body is still like new.
Offline mike_belben
  • Pulp Friction
« Reply #132 on: February 17, 2019, 10:44:00 AM »
Well the trailer booboo (like the wrecked steer spindle) is entirely my fault.  Id overloaded the trailer many times and rust had also taken its toll and started flexing the torflex mounting tab.  I knew it needed fixed but couldnt get the trailer to my welder and vice versa down here in TN.  Figured im going up empty, ill weld it at my dads.  His yard was a disaster of disassembled vehicles, no chance.  The load was pretty light and i lost the gamble that id make it down to TN and fix it at a friends shop.  Now instead of $10 in consumables its $1000 in special order parts and not having my trailer or the load sitting on it for a year.  My coates tire balancer may be junk now.
Live and learn i guess.  Its not like im out taking vacations and buying golf clubs. I try to maintain things as best i can and lose that battle on occasion for having too much to maintain on zero dollars.  All i ever do is work and just, just barely get by.  Like all the belbens before me.  we are well suited to it atleast.
Revelation 3:20
Offline Randy88
« Reply #133 on: February 17, 2019, 02:44:18 PM »
Yea I know how you feel, your not the lone ranger on just getting by, I tend to view it as a good year if at the end, I had enough money to pay all my bills and buy all the parts I needed for the year, most years I'm usually short on paying for all the parts.
But look at the bright side, when we're old and mumbling to ourselves, just think off all the stories we have to tell kids, what do those that have never fixed anything have to say, gosh all I ever did was wash the windows and fuel it up??
Offline snowstorm
« Reply #134 on: February 18, 2019, 05:47:15 AM »
i got the ih inside sunday. now that the ice and snow melted i can see what failed. the saddle that sets on the rear end with the spring stack on top of it broke. bolth sides. so the rear went back and sideways just enough for the slip joint on the drive shaft to come apart. to tow it home i toke the drive shaft out...well both pieces. a 25ft chain and we were off
Offline Don P
    • Calculator Index
« Reply #135 on: February 18, 2019, 07:17:08 AM »
That sounds like somebody backed up, gave her heck and rammed the pile.
Offline snowstorm
« Reply #136 on: February 21, 2019, 02:06:39 AM »
call dealer give him the vin yes i have the parts. wrong part what he had was for a 23k rear mine is 30k. backtrack 50 miles then 35 more to the spring shop. they have everything. she is back out side in the cold. the volvo missed the warm garage
Offline kiko
« Reply #137 on: February 23, 2019, 03:30:59 PM »
More gear carnage, both these showed up today.  Swing final and pump drive box.
Offline snowstorm
« Reply #138 on: February 24, 2019, 07:22:17 AM »
i put the outer axle shaft in the f550 yesterday. other than fighting rust. you have to heat everything or so it seems. the ujoint came from ford made by spicer. no grease fitting. i bet it outlasts 4 u joints from napa. the odd part was you have to pry the caps off to install the joint. they seal really well
Offline snowstorm
« Reply #139 on: February 24, 2019, 07:24:58 AM »
that would be one of those jobs... where do i start where dose it stop and how far away do i need to run
Daily Fabrication Thread
Started by mike_belben on Forestry and Logging
Last post November 22, 2020, 08:50:11 AM
by Firewoodjoe
Carnage
Started by Maine logger88 on Forestry and Logging
Last post December 05, 2019, 06:15:56 AM
by snowstorm
Todays carnage
Started by Kevin on Forestry and Logging
Last post October 25, 2006, 04:25:10 PM
by rebocardo
Guess the carnage
Started by moosehunter on General Board
Last post April 22, 2019, 08:33:44 PM
by terrifictimbersllc
