BLUECREEPER Poster Award #4!
Rob in WNY and 2 Guests are viewing this topic.
Thanks gang. Where is the service/run switch located? I havent had much work since thanksgiving eric, dont tease me with visions of fat pay checks!
If my calendar and memory are correct, you should be headed home around mid-week?
Quote from: Old Greenhorn on January 04, 2020, 07:11:49 AMIf my calendar and memory are correct, you should be headed home around mid-week?Sitting between Bannermans island and Storm king waiting out the fog, as long as we are to the city for Tuesday I'm good. Rumor mill says it's going to be in Eastchester / Bronx which works out ok. Gf leaves for work 1hr before I get home, she's not dealing with tugboating very well. Wednesday morning may sound like Eric Church's "wrecking ball", I should send flowers and a card to the neighbors now.
What brand of forwarder is that, bushmechanic?
Well I might as well add to this thread as well! First day back to the woods this fall and got to 4:00 pm before this happened... (Image hidden from quote, click to view.) (Image hidden from quote, click to view.) <br(Image hidden from quote, click to view.) and what it looked like after bush repair(welding)(Image hidden from quote, click to view.)
Forgot all about this thread even though I had my fair share of carnage this year.Started the summer by have hydraulic issues with a tractor. It has a closed center load sensing system and it was getting "hung" in high pressure and going over relief all the time heating the oil to scorching levels within minutes of running. So had plumbed in gauges to pinpoint things.(Image hidden from quote, click to view.)That was all well and good until my gauge was sticking out and the 3 point ripped the pressure pipe right off the valve block.(Image hidden from quote, click to view.)Pulled out the combing valve (tractor uses two open center gear pumps in tandem) to find a broken spring keeper and other trash stuck in there.(Image hidden from quote, click to view.)(Image hidden from quote, click to view.)(Image hidden from quote, click to view.)That resulted in pulling the pumps and locating the source of the trash which was a detent spring from the loader valve. So one new pump, new loader valve, bunch of new orings and backup seals, multiple system flushes and I was back in business.(Image hidden from quote, click to view.)(Image hidden from quote, click to view.)
Started by mike_belben on Forestry and Logging
Started by Maine logger88 on Forestry and Logging
Started by moosehunter on General Board
Started by Kevin on Forestry and Logging
