Author Topic: Daily carnage thread  (Read 36929 times)
Offline chevytaHOE5674
  • Forester
Re: Daily carnage thread
« Reply #200 on: October 12, 2020, 11:16:37 AM »
Has a 105hp Yanmar. 3k hours and just had to to a head gasket. Other than that its been good. Working on it is much easier than the bobcats and NHs that I've worked on. To run tracks it has 2" wheel spacers making it 7'4" wide. It's long in the backend, and weights nearly 12k lbs with tracks on. Even with tracks she doesn't like soft ground at all.. The vertical lift is wonderful but all the linkage does give you some inherent slop.
Parts other than the Yanmar are proprietary but availability is good and prices aren't too bad.
If you have lots of open space and hard ground they are awesome as it'll lift more than you can imagine. Tight spaces and soft ground you will cuss.
Online mike_belben
  • Pulp Friction
« Reply #201 on: October 12, 2020, 11:38:41 AM »
Is it a mechanical diesel or computerized with egr and def and all that?
Psalm 37:16
  • Forester
« Reply #202 on: October 12, 2020, 11:41:08 AM »
Mechanical, 12v is all she needs to run. Stay away from the perkins they were plagued with problems in the newer 10 series.
Online mike_belben
  • Pulp Friction
« Reply #203 on: October 12, 2020, 11:42:58 AM »
Thanks for the info, good stuff.
Do the tracks get you out of trouble or just lure you into it?
Psalm 37:16
  • Forester
« Reply #204 on: October 12, 2020, 12:02:49 PM »
Lure you into trouble. Haha they are better than tires for sure. But a lighter machine like my buddies NH LS180 will run circles around my Gehl in soft ground.
Online mike_belben
  • Pulp Friction
« Reply #205 on: October 12, 2020, 02:33:22 PM »
Wow that bad huh?  really puts perspective on it.  A 180 is no featherweight!
Theres a 980 bobcat with planetary hubs complete and running for sale nearby [rare anymore] and i look at it and think imagine what it could load and dig up.. But its 15k# and super wide with a short wheelbase, maybe even square.  Reality bites me and says imagine how bad it can bury itself.  15k is a loaded service truck or daycab tractor. Itll make a pigpen out of any site.
Psalm 37:16
  • Forester
« Reply #206 on: October 12, 2020, 03:59:34 PM »
His LS180 with tracks and bucket scaled out at just over 8k lbs i think, my 7800 with tracks and grapple bucket is 12,600 lbs. That is a lot of weight with not a ton more track area on the ground. Also hard to move as its too heavy and wide for most tandem "car style" trailers. So a deckover is a must.
Offline moodnacreek
  • Sawin by the notches
« Reply #207 on: October 12, 2020, 07:09:42 PM »
If my calendar and memory are correct, you should be headed home around mid-week?
Sitting between Bannermans island and Storm king waiting out the fog, as long as we are to the city for Tuesday I'm good. Rumor mill says it's going to be in Eastchester / Bronx which works out ok. Gf leaves for work 1hr before I get home, she's not dealing with tugboating very well. Wednesday morning may sound like Eric Church's "wrecking ball", I should send flowers and a card to the neighbors now.
The mouth of moodna creek is opposite Bannermans, between Plum point and  Cornwall landing. You where close [ to me]
Offline thecfarm
« Reply #208 on: October 12, 2020, 09:09:33 PM »
I have some rocks that I could use that to haul them away up into the bog!!! All I can do now is roll them.
Online mike_belben
  • Pulp Friction
« Reply #209 on: October 17, 2020, 09:09:00 PM »
Hey southside...
You reckon i got all the squeel outta that one yet?   ;D
Bead of the rim was shot from foam keeping the water in.  Even with tons of grinding it leaked like a screen door.  DAP weldwood contact cement.  Perfect seal.
Psalm 37:16
Offline BargeMonkey
« Reply #210 on: November 05, 2020, 08:37:13 PM »
Swing the engine at 0930,
 She was running about 4.
 Needs a couple minor things, put the rest of the panels on, wanted to get it off that hill before the snow came back. 2.45yd, should bail some dirt, thumb is like brand new.
  should be home monday, throw it in the pit.
Offline Old Greenhorn
    • Woodsman Forest Products
« Reply #211 on: November 06, 2020, 05:35:45 AM »
Nicely done. Fast too!
Oscar 328 Band Mill, Husky 450, 372 (Clone), Mule 3010, and too many hand tools. :) Retired and trying to make a living to stay that way. NYLT Certified.
OK, maybe I am the woodcutter now.
I can work with wood, but I am NOT a Woodworker, yet.
Online mike_belben
  • Pulp Friction
« Reply #212 on: November 09, 2020, 08:32:23 AM »
My 01 F250 4x4.  It was my grandfathers last truck and mostly sat parked in massachusetts.  I got it at 87k miles, completely rotted. What a shame.  Every brake caliper on it has hung up and turned the rotor red.  Never happens at a good time and always messes up your day.
These stupid phenolic pistons love to collect grime inside the bore and then refuse to retract.  If you catch it soon enough you can pop them out with air into a 2x4, sand them up and reinstall [minus the dust seal because it will never go back on right] and get some more time out of it.  If they get hot enough they shatter the piston and get stuck on the axle.
  Theyre about $100 each and you must bring the bracket with your core because ford used so many different calipers.. Sold with new slide bracket.  If any if you have one of these trucks and are suddenly slowing down fast, smelling brakes and getting bad mileage, feel your rims.  The hot one is hanging.
I wont have another one of these 5.4 triton trucks.
Psalm 37:16
Offline Nebraska
« Reply #213 on: November 09, 2020, 09:23:42 AM »
My Ford F350 has done the same,  mine have all been  done in the last 3 years. Still goes though.
Offline Ed_K
  • Leave it better than you found it. Ed_K
« Reply #214 on: November 10, 2020, 06:39:01 AM »
 My 05 GMC did it too :(.
Offline GRANITEstateMP
  • LIVE FREE OR DIE
« Reply #215 on: November 11, 2020, 03:58:31 PM »
I love disc brakes, but being in New England, salt, brine, rust really kills calipers quick. Still rather put on a new caliper than play with rotten backing plates and shoes that's never fun!
Hakki Pilke 1x37
Kubota M6040
Load Trail 12ft Dump Trailer
2015 GMC 3500HD SRW
2016 Polaris 450HO
SureTrac 12ft Dump Trailer
Offline nativewolf
  • Forester
« Reply #216 on: November 11, 2020, 04:41:09 PM »
We had a large wo roll over on a 462 as it turned out to be rotten and rolled during bucking.  Morale: keep other saws away from logs when bucking in dark :(.  Broke a few fins, handle is not good.  Have another top end might switch it up one day.
Liking Walnut
Online mike_belben
  • Pulp Friction
« Reply #217 on: November 11, 2020, 07:08:31 PM »
Thats a bummer wyatt.  It didnt take me long to realize there is no easy money waiting out in the woods.  Some days lucky to break even after deducting whatcha just plain broke.
Psalm 37:16
Offline g_man
« Reply #218 on: November 17, 2020, 06:59:39 PM »
I might need some new wheel bearings for the wood splitter soon....
gg
Offline barbender
« Reply #219 on: November 18, 2020, 12:51:32 AM »
Spherical bearing gave up the ghost on the lift cylinder of the forwarder-
Carco model E! Not daily carnage
Started by Satamax on Forestry and Logging
Last post April 05, 2021, 03:22:11 PM
by Satamax
Daily Fabrication Thread
Started by mike_belben on Forestry and Logging
Last post Yesterday at 11:08:03 PM
by mike_belben
The Daily Firewood Picture Thread
Started by mike_belben on Firewood and Wood Heating
Last post May 14, 2021, 08:39:23 PM
by cutterboy
Carnage
Started by Maine logger88 on Forestry and Logging
Last post December 05, 2019, 06:15:56 AM
by snowstorm
